Author Topic: Static timing on an Audi 80 2.0 (ABT) ... automatic!  (Read 13193 times)
Offline Ben Lessani
Re: Static timing on an Audi 80 2.0 (ABT) ... automatic!
« Reply #10 on: 24 August 2011, 10:20 »
All sorted now, lined up as you said. Test started it and it ran perfect.
The *only* thing that concerns me is that the tensioner seems to be 'loose'. There is 1 stud which is pivots on, that even when tightened up - the tensioner (brand new) has movement on, is this normal?
On the Golf IIRC, the pivot stud is also what secures the tensioner, but on the Audi, there is a sprung mechanism that secures the tension - but the marginal play is still alarming, I've never come across this before.
Not mine, but the tensioner arrangement is the same.
« Last Edit: 24 August 2011, 10:37 by Ben Lessani »
Offline AudiA8Quattro
« Reply #11 on: 24 August 2011, 17:59 »
How much play exactly?
There is likely to be marginal play, its a thermal type tensioner i believe.
Does the belt stay at the correct tension as you turn the engine over by hand?
