Golf mk3
hardmonkeys
gearbox
Topic: gearbox (Read 2095 times)
thai-wronghorse
Serious forum addict
mk1 Seat Leon FR TDI
Re: gearbox
Reply #10 on:
22 August 2011, 18:08 »
Or say bye bye Mr Clutch plate.
nikkiy9
GTI forum regular
Re: gearbox
Reply #11 on:
22 August 2011, 20:31 »
I'm not that stupid haha, managed to take the rubber cover off the clutch cable and the spring is semi compressed (facebook pictures will not upload) but I will upload it and post it
nikkiy9
GTI forum regular
Re: gearbox
Reply #12 on:
22 August 2011, 21:07 »
this is the spring on the clutch cable, is it over adjusted or is their still loads to go?
also, whats the best tool to use to crack open the drain and filler on the box?
harlemex
Re: gearbox
Reply #13 on:
22 August 2011, 22:33 »
17mm hex.
Wayne
Sir Postalot
Re: gearbox
Reply #14 on:
23 August 2011, 00:03 »
Better to fit a new cable for what they cost.
Seanl
Re: gearbox
Reply #15 on:
23 August 2011, 09:16 »
As said before you need a 17mm hex. Failing that, in true haynes tip style, a bolt with a 17mm head, with 2 nuts on, and use the inner nut to undo and tighten it back up.
nikkiy9
GTI forum regular
Re: gearbox
Reply #16 on:
23 August 2011, 09:39 »
i've just ordered a 17mm sump plug key so i'm just waiting on that before i do the oil change, i don't wanna as i hate the smell of gearbox oil, putrid cat pee smell
Golf mk3
hardmonkeys
gearbox
