Author Topic: golf mk3 temperature trouble  (Read 2148 times)
Offline vwburty
« on: 20 August 2011, 20:36 »
ih there, i have golf gti mk3 8v and having trouble with my temperature, car idles great , maybe alittle un powered ( feels like its trying to go but just cant get the last bit of power ) but in traffic the temperature sits half way but driving out of town it will drop down to 70 or just under and on the mfa the oil temp drops down to 66-70 while moving, the thermostat has been changed yesterday but didnt sort it. Anyone got some ideas?
thank you
Offline Seanl
Re: golf mk3 temperature trouble
« Reply #1 on: 20 August 2011, 21:47 »
If you've just changed the stat, make sure its bled properly. Massage the pipes til hot and hard.  :grin: with the expansion tank cap off.
Rev at 3000 rpm for 30 seconds, then let off and you should see it starting to bubble up. Do it a few times and this should clear it hopefully.
Offline vwburty
« Reply #2 on: 20 August 2011, 21:51 »
pretty sure thats been done already , all work has been carried out by my garage. could replacing the temperature sender unit sort this?
« Reply #3 on: 20 August 2011, 21:53 »
It might do but I would rebleed it 1st.
Offline vwburty
« Reply #4 on: 20 August 2011, 22:00 »
cool, ill give it a go in the morning , if not back to the garage monday lol thank you guys
Offline perks
« Reply #5 on: 21 August 2011, 15:16 »
Not sure if it's the same, but my Ibiza had similar issues. The stat housing had fractured, when the stat was trying to operate, instead of fully opening or closing it would just bend the damaged stat housing.
Got a replacement for pittance too.
Offline gremlin848
  • golf mk 8 gti and luv it to bits kings red all opp
« Reply #6 on: 24 August 2011, 01:43 »
on my gti the water pump impeller had come loose on the shaft new pump and housing sorted the problem
Offline vwburty
« Reply #7 on: 02 September 2011, 09:28 »
All sorted garage put a cheap thermostat on but now had a Vw themostat fitted and all sorted now but thank you guys for your replies and help :)
