Author Topic: running issue  (Read 1784 times)
Offline danmusic24
Re: running issue
« Reply #10 on: 18 August 2011, 12:17 »
yep 8v gti! so will grab leads and give it a go..you from lee-on-solent james?
Offline javalin
Re: running issue
« Reply #11 on: 18 August 2011, 13:06 »
no, nr Basingstoke, Hants.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline gasketface
Re: running issue
« Reply #12 on: 20 August 2011, 13:35 »
I had this lag on a car i bought a couple of months ago.Cleaned throttle body with carn cleaner (loads of) but made no difference.Cleaned maf sensor same way and lag cured !.
Offline danmusic24
Re: running issue
« Reply #13 on: 20 August 2011, 16:57 »
how did you go about cleaning maf? it looks fragile....
Offline Seanl
Re: running issue
« Reply #14 on: 20 August 2011, 18:16 »
Remove it from the housing very carefully! Clean it with contact cleaner, and a cotton but but obviously be very gentle as well with the cotton bud. Works a treat, this has happened to me twice as well. I always suggest this first for anyone experiencing this sort of problem before going and forking out for Coils, Dizzys, Crank sensors etc etc........
Offline danmusic24
Re: running issue
« Reply #15 on: 20 August 2011, 18:20 »
so is it contact cleaner or carb cleaner for the job?
Offline Seanl
Re: running issue
« Reply #16 on: 20 August 2011, 19:12 »
Contact cleaner!!!! Its electrical so it needs to evaporate. Dont put carb cleaner on it! Carb cleaner for throttle body.
