Author Topic: GTI 8v to vrSEX  (Read 5366 times)
Offline sharki786
  • GOT BOOST??
GTI 8v to vrSEX
« on: 16 August 2011, 23:01 »
i have been looking around the forum for over an hour and seem to have made a list, i love the car and has many memories so wont sell up and buy a VR! :grin: cheeky enough.
due to me having the mk3 8v anniversary, i have 288mm brakes etc etc
anyway this is the list i have made a list, which consists of:
ENGINE
GEARBOX
ENGINE LOOM
ECU
KEYCHIP
TRANSPONDER RECIEVER
HYDRO CLUTCH (clutch pedal, spring & master cylinder)
SPEEDO/CLOCKS
MANIFOLD
DOWNPIPE
DRIVERS SIDE ENGINE MOUNT
VR6 RAD+FAN
GEAR LINKAGE
DRIVESHAFTS??-will my 8v drive shafts do?
is there anything else i will need?
Many thanks for looking & helping/advising!!!
Sharki
*****MK3 Anniversary*****
*****MK4 GTI T*****
Re: GTI 8v to vrSEX
« Reply #1 on: 16 August 2011, 23:41 »
I think you have it all covered :afro:
Helpfull thread: http://www.golfgtiforum.co.uk/index.php?topic=124485.0
Offline sharki786
  • GOT BOOST??
Re: GTI 8v to vrSEX
« Reply #2 on: 16 August 2011, 23:51 »
cheers wayne (i knew you was going to post that link to the convo FAQs) you done that in ALL of the vr6 convo threads :grin:
cheers bud :afro:
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
Re: GTI 8v to vrSEX
« Reply #3 on: 17 August 2011, 01:05 »
p.s will the rado 2.9 engine, loom, basically everything from a rado fit my mk3?
*****MK4 GTI T*****
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: GTI 8v to vrSEX
« Reply #4 on: 17 August 2011, 08:41 »
you dont need to change driveshafts mate they are all the same
rado set up would work and be a good find too  :wink:
Not no ordinary GTI....
www.mixcloud.com/kells/
Re: GTI 8v to vrSEX
« Reply #5 on: 17 August 2011, 09:06 »
Not sure if the loom would work as the Corrado is based on a mk2.
Offline F17BAD
Re: GTI 8v to vrSEX
« Reply #6 on: 17 August 2011, 10:32 »
loom will be fine
Offline VR6_Wherry
Re: GTI 8v to vrSEX
« Reply #7 on: 17 August 2011, 10:46 »
Kells is our Mk3 engine conversion specialist now!  :cool: :grin:
Re: GTI 8v to vrSEX
« Reply #8 on: 17 August 2011, 10:51 »
loom will be fine
 :undecided: I seem to remember RJ saying that not a lot would swap from a Corrado
Offline F17BAD
Re: GTI 8v to vrSEX
« Reply #9 on: 17 August 2011, 11:04 »
fuse box is the same, its a CE2 fusebox like on MK3 so should plug in just fine, theirs only like 3 plugs that need removing to get  the old engine loom out and then those 3 will plug back in from the donor loom
