Author Topic: Measuring coilover drop  (Read 4054 times)
Offline Bellend
Re: Measuring coilover drop
« Reply #10 on: 17 August 2011, 17:24 »
Impact wrench will be fine. Give a local garage a fiver to loosen them.
Where all my moneys went.
Offline nathanpotato
« Reply #11 on: 17 August 2011, 18:19 »
Thanks for the replies i will give them a soak over night and if that dosnt help then i will have to find a garage tomorrow cheers
Offline Screech16v
  • MK3 20vt AGU
« Reply #12 on: 17 August 2011, 18:59 »
No need for garages, get some mole grips on the shaft between the coil spring then get your bar on the top nut,sorted   :wink:
« Reply #13 on: 18 August 2011, 08:26 »
ahh that sounds worth a go so put the mole grips on the shaft lower down sort of behind the wheel? Giving me more room to use the bar on the top yeah? cheers
Offline MK4D4VE
« Reply #14 on: 18 August 2011, 08:35 »
Just use a swan neck ring spanner and allan key that can be connected to a socket, you shouldnt have any problems then or need to use anything else.
Golf MK4 1.8 20v GTI
« Reply #15 on: 18 August 2011, 11:38 »
I gave it another go earlier and ended up rounding off one of the alan key bits so then tried the mole grip thing but could not get it tight enough to stop from slipping so the shaft just kept spinning around. I think a garage is my only option now.
Offline MK4D4VE
« Reply #16 on: 18 August 2011, 11:55 »
The only other option then is which someone has already suggested. The allan key part connected to the actual shaft of the suspension so get a set of adjustables and grip them around the piston shaft itself - tight. Get someone to hold them whilst you undo the top nut.
You shouldnt really need to pay a garage.
Offline murraymint
« Reply #17 on: 18 August 2011, 17:54 »
if the mole grips slip on the shaft of the suspension i found that raping some electrical tape round it first helped grip a lot
josh
« Reply #18 on: 18 August 2011, 21:31 »
Hey thanks for all the help I ended up just paying £5 to get it done but got them fitted now finally. Cheers again
