Author Topic: can i use t -cut ?  (Read 4563 times)
Offline fireman sam
can i use t -cut ?
« on: 16 April 2005, 11:26 »
well my 5 year old son decided he'd wash the car this morning and spent along time rubbing on some bird droppings - end result as expected i took the car to be washed properly.
when i got home and it dryed off to my horror the paintwork is all marked where the bird mess was.
it is mk4 standard black colour- can i use t cut to rectify or will it ruin whats left of the paint. i'm not sure if it's a metallic paint or not. i've been told in the past you shouldn't tcut met paint?
help !
Offline *Dubby*
Re: can i use t -cut ?
« Reply #1 on: 16 April 2005, 11:48 »
try turtle wax color polish and plenty of elbow grease first  :wink: this should get rid of most of it if its not too deep  :smiley:
Jeeeeeeeeeeeeeeeeeeeeeeeeep
Offline richandhazel
« Reply #2 on: 16 April 2005, 12:04 »
With a metallic you have a base coat and lacquer paint system. As long as the damage is light and not throught the lacquer you should be able to polish out the scratches with T cut. The danger is if you compound it too much you could cut through the lacquer to the base coat thereby losing your gloss finish in that one spot. So, you can give it a try but go easy and don't remove too much lacquer........from what you have described I would have thought the damage would be easily removed with T cut.
Offline BOGGLE
« Reply #3 on: 16 April 2005, 13:38 »
Like richandhazel says you have to be very careful with T-cut.  I always use Mer and it does a great job of getting rid of marks and sh!te :smiley:
Before....During.....After
Offline fireman sam
« Reply #4 on: 16 April 2005, 16:33 »
thanks guys i'll give it a go later. does any one if it is met paint with a laquer on the black mk4 golf. i've got lots of little scrtches i had left . i might sort thm all out if i won't ruin the paint.
Offline Jimbo Mc
« Reply #5 on: 16 April 2005, 20:08 »
There are 2 Blacks, non metallic and metallic, ones called diamond black and I cant remember what the others called sorry!
MK4 2.0 GTI!, MK4 1.8T GTI, MK5 GT TDI 140, MK6 GTD.....loved em all!!!!!!!!!!!!!!!!
Offline fireman sam
« Reply #6 on: 16 April 2005, 20:22 »
it's a 99 on a t plate if that helps
Offline Jimbo Mc
« Reply #7 on: 16 April 2005, 20:59 »
The non metallic is just called black, the metallic is called diamond black pearl effect, you can tell by looking close up, if it looks like its got 'sparkly' bits in it then its the metallic, if not then it should just be base colour black.
I used the gentle tcut colour restorer stuff on my last MK4 which was non metallic and had to stop as it dulled the paint finish really easily.
Offline fireman sam
« Reply #8 on: 16 April 2005, 21:04 »
well now i am confused. what did you end up doing with yours? respray or just left it
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 16 April 2005, 21:26 »
it sounds like you've only washed it.. as said above give it a good waxing with plenty of elbow grease on the marked areas... you'll be suprised the difference it makes.
