Author Topic: Fastest Mk3  (Read 2031 times)
Offline Dan_GTi8v
Re: Fastest Mk3
« Reply #10 on: 14 August 2011, 14:27 »
check the dub rides part of the VW related chat section, there are a few 1.8t builds in there with good pics and info. I have a thread in there which I stopped updating shortly after the conversion so its around page 4 or something, some others to look as are kells (now F17 BAD) which should be on the on the first or second page, and Lazy Lunatics should be near the front as well, although his thread is around 250 pages and has a looot of unrelated stuff in it as well! Also check Tshirt2k thread he's put a turbo into his abf 16v
Its fairly straight forward to drop in a 1.8t, dont get put off by people saying just buy a mk4. I'll never regret doing mine and have lost count how many times I was told it was a bad idea! Some advice I will give you though is if you are serious about it dont start with a 1.4, its a hell of a lot of work getting it ready for the extra power you would be much better starting with a GTi which already has the uprated brakes etc that will be needed to handle a 20vt. LL used a 1.4 I think check his thread if you wanna see whats involved, think it starts around page 30. What it will cost to prep the 1.4 would probably be more than just buying an 8v GTi  :wink:
Offline Ess_Three
Re: Fastest Mk3
« Reply #11 on: 14 August 2011, 14:46 »
Ok pal - nice one 4 the advice - will have a look into it and show the progress on which i get to slam in lol - i like a challenage not just the simple route of buying a faster car as i been told..
The point is, you have the wrong base car.
All your suspension, brakes, cooling system etc is wrong for the high powered engines.
You'd be better starting with a non-running 16v and dropping a K04's 1.8T in, at least that way your gearbox, driveshafts, hubs, suspension, brakes etc are up to the job.
You'd have to change all the running gear of your 1.4 to GTI/VR6 spec stuff to make it safe.
..but gaining motorcycles.
Re: Fastest Mk3
« Reply #12 on: 14 August 2011, 16:43 »
Spot on Glen, starting with a 1.4 = ballache, not worth the hassle or expense.
Offline murraymint
Re: Fastest Mk3
« Reply #13 on: 14 August 2011, 17:23 »
same problem as me, i've got a 1.6 so im saving for a 16v gti n then gunna do a 1.8t conversion
josh
