Author Topic: buy some underbody seal!  (Read 1468 times)
Offline tweed
« on: 13 August 2011, 21:39 »
Cutting the storey short I used some underbody seal on my sill's today. They are fine only having done 30,000 miles but was showing some small signs of surface rust. So I got some body seal knowing that they can rust away  :grin: I also done all four arches and done pretty much the whole two front inner wings lol
Basically I'm telling you lot to check yours and protect them now before it gets too late. all ya need is a wire brush and a tin of body seal
My vr6 has done 82,000 and it need some work due to rust  :sad: just wish someone had looked after it early on
Gavv8
Re: buy some underbody seal!
« Reply #1 on: 13 August 2011, 21:58 »
Did the sills and arches on mine a few weeks ago, used a good coat of waxoyl.
Offline tshirt2k
  • Been there...Done that...
« Reply #2 on: 13 August 2011, 21:58 »
You really need to treat the rust 1st with something that neutralises it. Otherwise it will still continue to travel under the factory sealant. In the process of sorting mine. The gti plastic sill covers do a good job of trapping mud and water. So that's where it starts around the wheel arches.
Waxoyl is not as good a bilt hambers dynax s50, which runs everywhere.
« Last Edit: 13 August 2011, 22:00 by tshirt2k »
Mk3 ABF 16VT Megasquirt V3
Offline Seanl
« Reply #3 on: 13 August 2011, 22:02 »
Got some Kurust and some waxoil to sort mine in the near future.  :wink:
Offline kempie
  • where would we be without duct tape?
« Reply #4 on: 14 August 2011, 22:47 »
im one step ahead of you guys, the engines getting dropped soon for a rebuild so im gonna get at this aswell, anyone recomend some undersealer?
Offline tshirt2k
« Reply #5 on: 28 August 2011, 17:11 »
You want underbody wax. Dinitrol or dynax UB.
Offline pigbladder
« Reply #6 on: 28 August 2011, 18:53 »
agreed you want dinatrol or bilt hamber , waxoil is worthless it just hides stuff and lets it carry on rusting
Offline gasketface
« Reply #7 on: 28 August 2011, 19:31 »
After rust treating i use this stuff.It goes on nice and thick,has a sort of bounce to it when stones etc hit it and wo'nt ever come off.It's real messy to work with though.Wear gloves and mask anything off you do'nt want it on.Petrol will remove any unwanted stuff.Also works well on bonding headlight lenses.Did i say it was messy ?.IT IS VERY MESSY !.Takes 24 hours to cure fully.
http://www.ebay.co.uk/itm/WINDSCREEN-GLASS-SEALANT-BONDING-ADHESIVE-GLUE-CAR-/370240015556?pt=UK_Body_Shop_Supplies_Paint&hash=item5634064cc4
