Author Topic: just got mk 3 gti  (Read 4858 times)
Offline allenthehat
Re: just got mk 3 gti
« Reply #40 on: 19 August 2011, 12:41 »
Cheap repair then. Good stuff.
Mk3 Golf GTi 8v.....thats how I roll
Offline claretsimon
« Reply #41 on: 19 August 2011, 15:24 »
hi guys just an update, so i replaced the abs/ airbag light switch as it was smashed up, the abs light comes on but then goes off like it should, however the airbag light lights and stays lit, any idea what this means? cheers
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #42 on: 19 August 2011, 20:38 »
You need to run Vagcom diagnostics and this will tell you where the fault lies, it's most probably a broken ABS sensor on one or more of the wheel hubs.
Offline Screech16v
  • MK3 20vt AGU
« Reply #43 on: 19 August 2011, 20:59 »
You have a fault on the airbag system,get it scanned for error codes.
Offline stevolution
« Reply #44 on: 20 August 2011, 01:28 »
I personally dont think that is an mot failure.
Offline claretsimon
« Reply #45 on: 20 August 2011, 09:15 »
Already passed the mot mate :smiley:
Offline Seanl
« Reply #46 on: 20 August 2011, 09:43 »
Did it pass with the Airbag light on??  :huh:
Offline brett
« Reply #47 on: 20 August 2011, 12:44 »
i thought it was a failure coz i panicked bout mine ,was nosying about one day and found mine had been pushed down into dash with lights glowing but luckily disconnected airbag and reconnected and cleared itself
Offline claretsimon
« Reply #48 on: 20 August 2011, 14:33 »
no the switch was already bust before the mot, placed new switch in now and get the airbag light staying on
