Author Topic: Loud Noise From Front Spring  (Read 4030 times)
Offline Ian Mac
« on: 13 August 2011, 16:07 »
My 52 plate 130 TDI has been standing for 2 weeks, sorted the flat battery only to find that when I steer there is a loud spring boong noise from the near side when I turn the wheel.
The top of the strut on the near side seems to have dropped and moves about more than the drivers side.
I jacked up the near side and had it on an axle stand (see previous post ref battery charger onto the starter motor)
Any suggestions on what might have gone on the strut
Ian
Offline old_n07
Re: Loud Noise From Front Spring
« Reply #1 on: 13 August 2011, 18:01 »
Could be a broken spring or collapsed bearing on the top mount, probably the spring though
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline Rhyso
« Reply #2 on: 13 August 2011, 18:16 »
+1 on what Neil said; 99% certain it will be the spring
Offline Ian Mac
« Reply #3 on: 13 August 2011, 18:29 »
I now have the car jacked up on both sides and the spring does not look broken. However when I pull the boot down from the top of the strut, on the pasengers side there is loose metal plate inside the spring, it looks as if it is the bottom of the top mount and that the spring should be sitting into it.
Anybody know if I can compress the spring in situ and change the top mount without taking the strut out ?
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 13 August 2011, 18:33 »
yes you can. probably need to detach the arb drop links to allow the hub to drop enough.
Offline Ian Mac
« Reply #5 on: 13 August 2011, 18:38 »
Thanks for the info, I will give it a go tomorrow - just need to try and get a top mount on a Sunday now
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 13 August 2011, 18:43 »
i'm really not sure from your description what has broken. can you get a quick photo?
Offline Ian Mac
« Reply #7 on: 13 August 2011, 19:55 »
the loose plate on top of the gator looks as if it should be part of the top mount?
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 13 August 2011, 20:11 »
thats part of the spring cap, must've sheared off from the rest of it. no wonder its making a noise :grin:
Offline Ian Mac
« Reply #9 on: 13 August 2011, 22:11 »
Managed to get the old one off with the strut inplace, it is deffo in more pieces than it should be. Hopefully a new one will go on OK without taking the strut out
Ian
