Author Topic: Just bought a brand new bee sting antenna for £5 delivered  (Read 3699 times)
Offline loz32
Re: Just bought a brand new bee sting antenna for £5 delivered
« Reply #10 on: 11 August 2011, 20:33 »
My J reg 16V had an amplification circuit in the base, water had got in and ruined it and thus ruined my radio reception, my cheap solution was to cut out all the base stuff (like polystyrene) and cut out the circuit, then solder a wire to bridge the gap in the base from the input to the antenna output. This way you get fairly good radio reception but its not amplified, it works fine for radio 1 etc. though prob. not as good as with the amp circuit, I couldn't tell you it was before I owned the car that the water broke it.
Offline maxp
  • J reg 8v digi gti
Offline loz32
« Reply #12 on: 11 August 2011, 23:17 »
Sorry for my ignorance, but will a replacement make my radio signal any better as it is currently rubbish :sick:
Thanks
+1
I think you need the base and not just the antenna..
I thought it was a sealed unit?
It is a sealed unit kind of. If you've got problems with poor radio reception and you've eliminated connections in the front of the vehichle and head unit, this is what I did:-
1) Undo the screws that secure your roof lining in place, be careful here, mine was fine, but a friend said the boot lining can lose its shape and sag if you force it down too far.
2) Undo the bolt securing the antenna base to the roof, if I remember correctly there's an earthing washer that cuts into the metal of the body work, check this earth is good with a multimeter.
3) If you have a powered antenna base like mine you'll have a 2mm wire going to it as well as the coax cable, this supplies the current for the amp circuit (the negative comes from the car earth). You'll need to cut this wire and insulate the powered end of it once you've established that your amp circuit is blown. I think the coax cable has a connector not far from the antenna base.
4) There is a rubber base to the base of the unit, I can't remember how its attached but I remember this stage slowing me down, I did manage to prise it off eventually and cos its made of rubber and I was careful it still looks A1 back on the car.
5) Now you should see the polystyrene looking material that fills the base, its there to stop water getting into the amp circuit, you just gouge all this out until you can see the circuit.
6) My circuit looked visibly damaged, blackened in places I think
7) If I remember correctly I then just cut the circuit out with wire snips at the top and bottom, then I think the wire that connected to the bottom end of the circuit was long enough to bridge the gap to the top of the unit where I soldered it to the connector for the mast screw fitting completing its connection to the coax. So your removing the to wires I think to the amp circuit, and bridging a single wire connection for the coax (the signal cable)
This makes it basically like any passive bee sting antenna. ie it works ok but not as good as a standard 1M steel one.
but hey, who wants to replace their antenna every 6 months? :-)
Offline loz32
« Reply #13 on: 11 August 2011, 23:20 »
Shameless plug:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300587757292&ssPageName=STRK:MESELX:IT
Sweet! Does the amplification circuit still work do you know? Is that your eBay account mate?
Offline maxp
  • J reg 8v digi gti
« Reply #14 on: 12 August 2011, 12:29 »
Yep it does work and yes that is my ebay account.
Offline loz32
« Reply #15 on: 18 August 2011, 20:52 »
Bought it, lets hope the amp circuit gives even better reception :)
Offline tomp
« Reply #16 on: 29 August 2011, 23:48 »
Just ordered one from Bulgaria on your recommendation...
