Author Topic: Fuel pump woes  (Read 2866 times)
Offline emery1990
Re: Fuel pump woes
« Reply #10 on: 15 August 2011, 20:54 »
Ahh ok, probably why its leaking, solved my issue, was a knackered wire to the injectors! Wasted all that time getting the pump out etc!!
Offline emery1990
Re: Fuel pump woes
« Reply #11 on: 17 August 2011, 19:00 »
Ill just put this question here. If my car runs on two cylinders and the spark plugs and ht leads to cyl 3+4 are fine, does that basically mean my engines f'd up.
Those cylinders spark plugs are clean, unlike 1+2 which are fine, theres are pitch black due to a rich map, 3+4 are clean due to sucking more air to make the mixture right? I'll get a compressor tester on it. not looking good though  :cry:
« Last Edit: 17 August 2011, 19:02 by emery1990 »
