Author Topic: Battery woes!  (Read 1423 times)
Offline drivebycar
Battery woes!
« on: 07 August 2011, 20:33 »
So I bought a new battery a couple of months ago and with it the golf was running beautifully. Since then it has stood for a few weeks without use.
I charged the battery for a few hours yesterday and she started ok. But now I've come back the next day to start it and it's flat again. It's a sealed battery also btw so can't top up with distilled water.
Do I just need a new battery then? Thought if it was brand new I would be able to charge it easily.
Normal is getting dressed in clothes that you buy for work and driving through traffic in a car that you are still paying for - in order to get to the job you need to pay for the clothes and the car, and the house you leave vacant all day so you can afford to live in it.
Offline sharki786
  • GOT BOOST??
Re: Battery woes!
« Reply #1 on: 08 August 2011, 00:41 »
if its a brand new battery then 2 things, either the battery was poo or there a problem with you alternator.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline drivebycar
Re: Battery woes!
« Reply #2 on: 08 August 2011, 07:34 »
I don't think it's the alternator as after charging the battery up, left it parked overnight and wouldn't start the next day. So it's not like it's running down as I use the car.
Offline Gti Gerbil
Re: Battery woes!
« Reply #3 on: 08 August 2011, 11:47 »
firstly
you need to check to see if the car has a current draw while turned off, I may be that which is causing your problems and not a lack of charging or a duff battery
If there is not quiescent current draw when the car is off, when it is worth checking the main charging cable, the one in my car had gone hard in places and even though 14.4V was showing at the batterery with the engine running no real current wads getting through to charge the battery (the one from the alternator to the battery)
You say your car is charging ok, how have you checked this ?
find me on skype : paul.taylor.999 .. Vagcom reads for all, with a free cup of tea
Offline drivebycar
Re: Battery woes!
« Reply #4 on: 08 August 2011, 12:41 »
Thanks for your replies. Had a discussion with the technician where I bought it and he said because it had stood for so long the plates had oxidised. So the charger has to break down these build ups before it can charge the battery properly. So fingers crossed, the other side of a very long charge it should be all good again :)
