Author Topic: Need to buy standard 16V springs, but where?  (Read 5359 times)
Offline The Mighty Elvi
  • I'm better than you today.
Re: Need to buy standard 16V springs, but where?
« Reply #10 on: 06 August 2011, 21:26 »
Go to the forum sponsors section. They gave us an online discount code.
« Reply #11 on: 06 August 2011, 21:30 »
I would switch to Eibach springs, will be a lot better than the cheap ones you have now.
Offline loz32
« Reply #12 on: 07 August 2011, 20:19 »
I've ordered the Eibach's with the 20mm drop from europerformance! Lets hope they do the trick.. I'll let you know.  Thanks for all the advice!  :smiley:
« Reply #13 on: 07 August 2011, 20:56 »
Good choice :afro:
Offline sprout99
« Reply #14 on: 07 August 2011, 21:39 »
i had them on mine .......front will sit a lttle lower than rear
i ended up removing one coil from rears to get perfect flat ride height
nice ride tho  not harsh and they black so look oem
(the fronts will come with coil protectors on - up to you if you leave them on)
« Last Edit: 07 August 2011, 21:41 by sprout99 »
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline loz32
« Reply #15 on: 09 August 2011, 20:25 »
These protectors they come with, are they like a rubber sleave that slides over the coil to prevent noise? I've heard the one downside to fitting Eibachs is that you get a metallic thud at low speed when hitting pot holes. Was wondering if that's what the protectors are for?
Thanks again
Offline sprout99
« Reply #16 on: 10 August 2011, 07:21 »
Thanks again
yup - i took them off and had no probs
Oak green mk2
V50 D5 Sportwagon
Offline loz32
« Reply #17 on: 13 August 2011, 14:41 »
Well my new Eibachs are here :) But shes not going anywhere till I do some more serious work on the brake callipers, soo rusty :(
If anyone's feeling really kind could they point to me a mk2 golf specific guide to fitting springs? Or tell me to stop being lazy and figure it out from the haynes manual.
I'm just fitting the springs btw, think/hope my bilsteins shocks are still good. But I think I might need new top mounts (is that what they're called?) on the rear.
