Author Topic: Just failed the MOT, any ideas?!  (Read 1891 times)
Offline Fallenidol1
« on: 04 August 2011, 18:57 »
Ok, so I've just returned with my car having failed it's MOT.
It's to do with the ABS light coming on. It comes on now and again, only typically it was on for the MOT.
If I'm driving and it comes on I can turn the engine off and on again and it will go out.
Is there any advice anyone could give me on either a) sorting the problem or b) keeping the light out for the purpose of the MOT re-test?!!
Cheers,
Dan.
Offline jigger01
Re: Just failed the MOT, any ideas?!
« Reply #1 on: 04 August 2011, 19:01 »
for the mot go to the scrappy and aquire the full cover from a non abs car if there is no light there they cant fail it .
red ones are best.
working progres
Offline Seanl
« Reply #2 on: 04 August 2011, 19:40 »
red ones are best.
Or actually fix the problem!  :rolleyes: :grin:
Probs just a sensor, common fault. Get it on VagCom and get the code read, it will tell you where the fault lies. Mine started intermittent, now its permanently on. Woth sorting as ABS failure can turn out to be a pretty serious problem!
Offline Gti Gerbil
« Reply #3 on: 04 August 2011, 19:42 »
screwdriver through the bulb sometimes works  :shocked:
find me on skype : paul.taylor.999 .. Vagcom reads for all, with a free cup of tea
Offline jigger01
« Reply #4 on: 04 August 2011, 19:49 »
lol yes that would do it also.
red ones are best.
working progres
Offline Seanl
« Reply #5 on: 04 August 2011, 19:57 »
Light should illuminate for a couple of seconds when the ignition is on. Unless they dont pay much attention, they will fail it on that. If you use the same garage they will know as well.
Offline AudiA8Quattro
« Reply #6 on: 04 August 2011, 20:17 »
This is part of the test.
Offline Fallenidol1
« Reply #7 on: 04 August 2011, 22:03 »
Ok thanks, a few things to look at, I'll try to clean the sensors first!
Offline Gti Gerbil
« Reply #8 on: 04 August 2011, 22:09 »
where you at maybe there is someone near you that can read the code for you and tell you what one requires hitting with a hammer, sorry.. meant fixing
Offline dom
  • Back in a Mk4
« Reply #9 on: 04 August 2011, 23:19 »
Ignore the stupid replies telling you to smash the lights or just disguise the problem. If the ABS light is on it is because you have a problem with your braking system, something which is pretty vital to your car.
As a first step get your car scanned with a fault code reader, my guess would be a faulty sensor(s) which is a cheap & simple job to sort :smiley:
