Author Topic: 16v power loss, jerking .....  (Read 3421 times)
Offline walchy01
Re: 16v power loss, jerking .....
« Reply #10 on: 10 August 2011, 18:17 »
Any ideas on prices for fuel pump and filters please....dont like cheap crap, quality parts that will last hopefully please  :wink:
Thanks
Offline walchy01
« Reply #11 on: 12 August 2011, 13:57 »
If this is a fuel filter/pump issue, would the problem be intermittent??? Drove the car about 1 mile and it was jerking as usual :sad: then restarted 5 mins later and drove fine for 1/2 a mike then back stuttering and jerking when accelerating...
Mmmmm this is pissing me off now  :sick:
Offline mk2bal
« Reply #12 on: 12 August 2011, 17:33 »
Have you pulled the fuel flow pipe off the metering head via the banjo bolt?  It should be under pressure, and when the pumps running, should piss fuel out. If it does, that proves the system as far as m/h, then its time to pull an injector(s) to prove flow. If none, work your way back, ie disconnect injectors from fuel lines and check for fuel there. You will need pump running and to lift air flap, this process is on here somewhere, have a search. Regarding fuel filter, any pattern one will do, its not got to last that long, as you should change it every 1/2 years. I used vwspares.co.uk for mine, was about a 5er, and was made by mann filters I think, which is a perfectly good enough make.
Offline walchy01
« Reply #13 on: 12 August 2011, 17:37 »
Thanks for that will give these things  a go.....
Offline walchy01
« Reply #14 on: 19 August 2011, 17:46 »
I think I've found it :grin:
On the plug lead where the lead goes into the chunky rubber that then pushes down onto the plug, I think it has come apart inside the rubber as it is not as stiff as the others, so there is a break in the lead, little bleeeeder......
Hopefully sort it next week :wink:
Back to normal... Can't wait, feel car sick everytime I get out at the moment :sick:
