Author Topic: Passat gearbox problems  (Read 1875 times)
Offline tonsofun
« on: 03 August 2011, 10:58 »
Last night my car (1.8 20v non turbo 1998 passat) shuddered to a stop, and now seems to be stuck in reverse gear, the car cannot be pushed or towed even with the clutch down. I am guessing the gearbox has gone.
Does anyone know which gearbox will fit, are they pretty universal like non older vag cars? As there seem to be more 1.8t gearboxes for sale than non turbo ones.
Any info would be great
Mark
2 Mk2's, both in bits, 2 Rocco's soon to become 1, and a Polo 1.3.....
The polo is the only car with MOT and in working order...Doh!!
Offline Len
Re: Passat gearbox problems
« Reply #1 on: 03 August 2011, 16:42 »
Get on UK Passats, they will know the answer!
www.sas.org.uk
www.the-ace.org.uk
Offline AudiA8Quattro
« Reply #2 on: 03 August 2011, 17:49 »
It does sound like the gearbox has gone.
I'm not sure what will fit, but i would of thought an audi gearbox is more likely to fit. Do these cars have in line engines?
Offline tonsofun
« Reply #3 on: 03 August 2011, 18:08 »
yer engine mounted front to back, instead of side to side. i guessed some audi would fit, but there are alot more tdi, and 20v turbo boxes out there than my type, dont know if they will all fit? obviously the ratios will be different, but it is only my run around and not too fussed, just need it back on the road asap!!
« Reply #4 on: 03 August 2011, 21:37 »
Tdi box will be no good due to the ratios, turbo box should fit all ok, same basic engine after all.
