Author Topic: headlight problem  (Read 797 times)
Offline DOBBY69
headlight problem
« on: 02 August 2011, 20:54 »
Hi,the guy i bought my Tdi from as hacked the headlight wiring
to fit some Morette headlights, he also fitted some wierd switch with 3 buttons on the dash??
Trouble is each time you put full beam on the headlights go off .there`s some kind of relay wired to them near the battery. Any ideas how to correct it,thinking of replacing them with GTi ones. Thanks
Offline DOBBY69
Re: headlight problem
« Reply #1 on: 04 August 2011, 08:51 »
HELLLLLLP !  :sad:
« Reply #2 on: 04 August 2011, 08:54 »
Might be better to scrap the switch / wiring and put it back to standard.
Easy enough to pick up a s/h lighting loom and switch
Offline Len
« Reply #3 on: 04 August 2011, 08:56 »
Normally Morrettes are just a play and play fitting!
So see what you have and ditch the bodge job.
www.sas.org.uk
www.the-ace.org.uk
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 04 August 2011, 11:46 »
New loom from a breakers for a few quid is definitely the way to go here.
