Author Topic: Tdi Flexi fuel lines  (Read 636 times)
Offline DOBBY69
« on: 02 August 2011, 18:38 »
Hi all, my Tdi needs some welding on the rear drain plugs in the floor,trouble is theres two
pipes (fuel i think) that run right between the holes, i need to move them over.They seem pretty flexible and are push clipped under the car.Is it possible just to unclip and tie outta the way?
Offline Dan_GTi8v
Re: Tdi Flexi fuel lines
« Reply #1 on: 02 August 2011, 18:46 »
tdi may differ but on the petrols theres 3, black is fuel supply blue is fuel return and white is the breather pipe. I'm guessing you just have blue and black if theres only 2. They are fine to be moved out the way just be carefull not to split them
Offline DOBBY69
« Reply #2 on: 02 August 2011, 19:06 »
Thanks for that matey :smiley:
