Author Topic: Painted calipers losing their shine.  (Read 3901 times)
Offline Jimble
« on: 02 August 2011, 11:37 »
I've noticed recently that my front calipers are starting to look a bit dull, the rears are like new, i only use bilberry wheel cleaner now and again so doubt it's that causing it and as i say the rears are fine.
When i rub them with a rag or microfibre the colour transfers to it?? I'm going to take the wheels off for the first time since getting the car so i can give them the treatment they deserve but is there anything i can do to my calipers? I suppose it'll have to be something that can cope with the heat?
Cheers chaps.
Re: Painted calipers losing their shine.
« Reply #1 on: 02 August 2011, 11:38 »
Snoothrite is spot on for painting calipers.
Offline Len
« Reply #2 on: 02 August 2011, 11:44 »
Yea Hammerite Smooth or actual caliper paint.
www.sas.org.uk
www.the-ace.org.uk
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 02 August 2011, 12:14 »
hammerite is fine tbh.. you can go VHT paint and lacquer which will be much better but they all lose their shine after a while.. it doesnt help on the front the amount of heat in the calipers due to breaking which the back dont have..
Offline Jimble
« Reply #4 on: 02 August 2011, 13:17 »
I thought it would be the heat tbh, i was kind of hoping to bring back the shine and protect it really rather than paint them, the cars only got 5500 miles on it!  :sad:
Offline _Adam_
« Reply #5 on: 02 August 2011, 13:54 »
are they bare metal? could you shine them back up then clear laqueur? :huh: just a thought.
i have used hammerite in the past - excellent except it takes AGES to dry.
Halfrauds do a cheap and cheerful quick dry caliper paint but it doesnt stay vibrant for that long :undecided:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #6 on: 02 August 2011, 14:10 »
Sorry mate they all go that way after a while unless done properly.. could always ask dealers to sort it but they 'may' laugh.. just wack some hammerite on them  :wink: unless they brembo type calipers then VHT paint  :smiley:
Offline Jimble
« Reply #7 on: 02 August 2011, 14:23 »
Not bare metal mate they're painted red from the factory.
Ah ok mate thanks, that sucks a bit though, you'd think they would use a paint that can take the extra heat?? :angry: Might try and buff them up a bit and put a couple of coats of Jetseal on to see if it helps at all.
Thanks for the comments though, much appreciated. :wink:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #8 on: 02 August 2011, 15:29 »
yer its worth a go.. but the way you said the colour comes off onto the cloth you use shows its a crap paint from factory  :angry:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #9 on: 02 August 2011, 21:27 »
Hammerite all day long
only takes ages to dry if u put too much on
Not no ordinary GTI....
www.mixcloud.com/kells/
