Author Topic: ECU Location and 8V Brakes on a Driver  (Read 1503 times)
Offline mak2503
« on: 14 April 2005, 12:20 »
I currently have a Golf MK2 GTI 8v that I am breaking and I was just wondering if someone could let me know the location of the ECU on this type of car. I have checked through the Haynes manual but cannot find anything.
Also my little brother has a MK2 Driver and I was wondering if it is possible to swap the discs and pads off the GTI onto his car.
Do I have to change the caliper as well or can I use the ones off the driver?
Offline ...joe
Re: ECU Location and 8V Brakes on a Driver
« Reply #1 on: 14 April 2005, 12:35 »
if your standing in front of the car looking at the engine the ecu is in the top left corner, normally under a plastic cover. if you look for the wiper mechanism then look left you'll see it.
the brakes should be a straight swap. the discs are vented an so the pads are that bit thinner to allow for this. you shouldn't have to swap the calipers.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline VWDino
  • MkII 1.6 Driver. GTi cam, K&N .....
« Reply #2 on: 14 April 2005, 12:39 »
Front Discs and pads are a straight swap from GTi to Driver. Fitted some to my 1.6. Discs are fatter but pads are thinner to compensate. No need to change calipers  :smiley:
« Reply #3 on: 15 April 2005, 14:35 »
What year is it?  Early GTIs didn't have an ECU ;)
Offline mak2503
« Reply #4 on: 15 April 2005, 20:36 »
The car is a D reg and I think it is a 1986.
It has the mirrors half way up the doors and the wipers on the wrong side if that helps.
Offline Dizzie
  • Make friends with your fast
« Reply #5 on: 15 April 2005, 21:50 »
there's no ECU then
Offline ...joe
« Reply #6 on: 17 April 2005, 19:49 »
sorry dudes, jumping to conclusions!!!
