Author Topic: Garage set up. Must have tool sets.  (Read 7345 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: Garage set up. Must have tool sets.
« Reply #30 on: 02 August 2011, 16:52 »
Kettle for cock-free-tea.
The mere presence of a kettle does not guarantee cock-free tea.
The threat of cock-ed tea is caused by letting a cock into your workshop.
Thankfully this is only an issue if the aforementioned apendage is long enough to reach into a mug.
Turns out some aren't, which is nice.  This does not stop them from thinking about further ruining an (already dreadful) cup of tea by introducing their cock into your workshop mug.
Just don't do it.  Keep your workshops cock-free for peace of mind.
 :grin: :grin: :grin: :grin: :grin:
Offline CCGTI
  • Fueled Society
« Reply #31 on: 02 August 2011, 16:53 »
massive screw driver for poking stuff
Offline bodga
  • F reg GTI 16v
« Reply #32 on: 02 August 2011, 19:41 »
Buy as you need them,
dont get lending them out without a deposit!
Buy cheap and the ones that break replace with quality. (the ones you dont use much wont have cost the earth :wink: and you can loan the cheap ones out :grin:)
Keep a set of spanners 6mm-24mm, screwdrivers, grips and pilers in the boot of you VW for quick roadside fix. also if you have a mk3 add ptfe and gaffer tape, just in case you spring a leak :laugh:
Offline danny_p
« Reply #33 on: 05 August 2011, 23:29 »
hose clip plyers
Prope wire crimping tool
contact extractors ( for wire loom plugs )
soldering iron
decent DMM
old laptop,  for playing tunes off  looking crap up on the net, etka elsa TIS vagcom ect
all the VW's have gone bar 1.
Offline Sammie-GTI
« Reply #34 on: 06 August 2011, 00:18 »
only one tool in my box and thats the persuader(large hammer)
Offline Ant1981
  • Feed me, prod me
« Reply #35 on: 06 August 2011, 11:04 »
One of my must haves which I use alot infact!
'09 Kawasaki Ninja ZX-6R
VW BUSH
« Reply #36 on: 06 August 2011, 19:07 »
Thats an old one, with extra mid section by the looks, I did my time on one just like it :cool:
Offline Ant1981
  • Feed me, prod me
« Reply #37 on: 07 August 2011, 10:50 »
I was surprised, even the 90's ones look like that. That's a photo from the net, but our one looks quite similar and it's a 90s machine.
Offline Ant1981
  • Feed me, prod me
« Reply #38 on: 07 August 2011, 10:52 »
i have a clarke low slung trolley jack would not live without it theres not a car it hasnt got under yet..
selection of pry bars
good quality axle stands.. i also have 4 12inchs tall stands for a car which when put on the car is well over a foot off the ground just a shame my jack doesnt lift high enough to put my car on  :grin: :grin:
My jack lifts quite high, but sometimes the car can get a bit unstable with the one stand on high before the one one has gone in!
Offline LowlifeDubber
« Reply #39 on: 07 August 2011, 16:10 »
Usual stuff as mentioned.
Also a compression tester
hub pullers
small flight press(save you fannying about going to a garage)
multimeter
selection of 5-10mm nuts bolts and washers
ball joint splitter
spline tool for inner cvs
Battery charger/booster
Clutch aligning tool(or make one)
HT tester
selection of podgers
irwin extractors
valve spring compressors
regular spring compressors
soldering iron
electrical insulation crimps
selection of insulated connectors
Theres lots you need.But buy as you require and you will soon have a good collection.
Remember if you need to borrow a tool twice then it's time to buy your own ;)
