Author Topic: Please help before I lose it! Crank sensor?  (Read 6814 times)
Offline Ninja
  • 19 smiles per gallon
Re: Please help before I lose it! Crank sensor?
« Reply #20 on: 01 August 2011, 12:54 »
Sounds like a cranks sensor.
HOWEVER - mine had the EXACT same issue as yours and it was an ECU earth. I found this out after i'd replaced every other f**king thing, including the crank sensor.
Offline patc
« Reply #21 on: 04 August 2011, 19:36 »
New crank sensor done (£32 from unipart)!  Has it solved the problem?  Has it fook!  :angry:
Gonna go down the fuel pump & ECU relay route tomorrow.  Last chance before I test the car off a big fooking cliff!
PatC
Golf GTI MK3 Anniversary Edition
Offline Ninja
« Reply #22 on: 04 August 2011, 20:37 »
Mate, seriously. Before you do that get an auto sparky to look over the car. Basically, like I said - mine was the same issue and was an ECU earth. I believe it was something like low resistance from the ECU to the crank sensor.
Offline patc
« Reply #23 on: 04 August 2011, 20:46 »
I left it at the garage so will ask him tomorrow.
Cheers!
PatC
Offline Ninja
« Reply #24 on: 04 August 2011, 22:21 »
Cheers!
No worries. Basically with mine, the reason it happend was because water had gotten under the battery tray and caused the wires to burn.
Offline patc
« Reply #25 on: 04 August 2011, 22:34 »
The state of the old sensor lead was a joke and would have needed replacing sometime soon anyway.
Is the ecu earth an easy check?
« Last Edit: 04 August 2011, 22:41 by patc »
PatC
Offline patc
« Reply #26 on: 05 August 2011, 18:04 »
Right. All done. New relays. New every bloody thing!
It does 'sound' better and start up instantly which it never did before. Time will tell!
Thanks for all the help on here!  I shall make a donation to the forum charity come pay day 
PatC
Offline bully79
  • getting there... slowly
« Reply #27 on: 05 August 2011, 18:52 »
Finally found out what was wrong with mine  :cool:.It was the ignition switch  :smiley:.So all's good,just need to get front speakers sorted for Harewood VW festival next week.
Offline patc
« Reply #28 on: 05 August 2011, 19:01 »
Ignition switch?!  Not another possibility!  How'd you find that out?
PatC
Offline bully79
« Reply #29 on: 05 August 2011, 22:05 »
When me n me dad were mucking about with it (checking all sorts) he noticed that when the key was turned to No 2 position (dash lights) everthing was fine,but if the key was turned very slightly (not actually cranking the engine) the lights went out :angry:.So I pulled the multiplug off and poked some wires in (hotwired mis spent youth) and the car was fine :smiley:.I bought a steering column off ebay and job done.
