Author Topic: Oxygen Sensor - intermittant fault  (Read 1377 times)
Offline granthar
« on: 13 April 2005, 10:53 »
Boght the OBD cable and VW Tools software. Ran the diagnostics and it said I have an itermittanr fault on the oxygen sensor???
Is this easy to replace and where is it? is it on the catalytic converter?
Offline AudiA8Quattro
Re: Oxygen Sensor - intermittant fault
« Reply #1 on: 13 April 2005, 14:32 »
It should be mounted in the front of the cat.
It may or may not be easy to remove, depends if its seized in.
Get one of those cut out sockets for the job, will reduce the risk of rounding off the nut.
Offline golf96
« Reply #2 on: 14 April 2005, 22:30 »
can i ask what your fault is that has made you look to see whats up with ya motor pleasde to see if its same as mine?
redcarboy
« Reply #3 on: 15 April 2005, 10:41 »
Take out the sensor first and clean it up then stick it back on and run the test again and if it is knackered they aint that cheep new  so a scrappers maybe the best place to get another.. :grin:
