Author Topic: Question for you Bike carbs or Twin 45's?  (Read 5778 times)
Offline Diamond Hell
  • Opinions я Us
Re: Question for you Bike carbs or Twin 45's?
« Reply #10 on: 25 July 2011, 08:10 »
Quite why you'd use any carb set up on a GTI 8 or 16V is a mystery to me.
Less economy, less performance and far more expense.  If you want a nice noise nail a VR6 in there.  If you want more performance get some throttlebodies on it.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #11 on: 25 July 2011, 10:31 »
Taken what you've said on board found this company that make throttle body kits
http://www.badger5.co.uk/
Offline DOA
« Reply #12 on: 25 July 2011, 10:41 »
Not here for an arguement but.....
I dont quite see the increase in expense here unless you are considering their use over a significant time frame. Face it, as nasty as carbs are when compared to a throttle body and stand alone ECU package thats set up properly, they are a very cheap option if all you want is some bragging rights, a bit of noise and a wee bit of extra oomph out of the engine (when set up properly, something I fail to see Bogg brothers doing just by banging in a set of rough guess jets btw). Its definately not what I would do and I do see some of your point (certainly regarding fuel economy and engine output/drivability potential) but a full on throttle body setup can be VERY expensive if you are not in a position to do the vast majority of the work yourself. Even using megasquirt and bike bodies your looking at a significant investment which a lot of people just are not capable of justifying or even implementing.
Lets do a quick tot up of some figures plucked out of the air shall we? £200-400 for a megasquirt ECU depending on who builds it or if its on ebay built, £50-200 for ignition parts and new leads depending on what route you take with the ignition (stock is useless and defeating the object), £50-150 for the TB's, £100-200 for the new loom including connectors and add in a fair bit more for crimping tools, vastly more if someone else does it, £50 for the inlet assuming you do it yourself, £200-350 for the inlet if bought out, several hundred for mapping if you want it bang on and your talking serious money to most people with what is a budget setup that would be roughly acheivable by most mechanically minded people.  Compare that to £350 for a bought inlet and maybe upto £100 for the carbs and theres not only a big difference in cost but also in time and skills required. BTW, Im aware you can do these things a lot cheaper than the rough prices I have popped in here but not everyone is capable of doing this sort of thing, let alone have the confidence to start such a project with their road cars.
Perhaps its worth you remembering this as it seems at odds with your constant banging on about using OEM brake setups to keep costs down (again, something I see your point with but is sometimes delivered in such a way as to make people ignore your vision on the basis you come across as a prick).......
Did you really suggest someone should put a VR engine in a car and not put a single snide comment in there  :shocked:?????
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #13 on: 25 July 2011, 10:53 »
Ive just looked at throttle bodies and for a kit your looking at £1500/£2200 for a decent kit which includes everything for about 25bhp increase.. you could easily turbo the car on standalone for that lol..
r1 carbs = £75
manifold = 200-350
carbs are definately cheaper lol whats the difference on bhp between the 2 ??
Offline DOA
« Reply #14 on: 25 July 2011, 11:34 »
Its not just the output, its the way that output is delivered  :wink:.
If all your worried about is figures then either method could probably acheive the same level of outright power (assuming you can play with the timing to suit the carbs properly) but, as good as bike carbs are for drivability when set up well (the reason bikes took so long to swap to injection in the first place on sporty models appears to be low range throttle pickup sensitivity), you will really struggle to get a carb setup to have as broad and level a torque curve, have the potential to improve fuel economy, improve transient and steady state throttle response, meet emissions standards, etc, etc. If your after the best setup, throttle bodies and standalone is definately the way to go, if your happy to make a lot of compromises then carbs and programmable ignition is fine and if your willing to compromise further, carbs with no ignition mods is also doable and manageable on the road but the final two options are just not going to get the same results as a decent throttle body setup. The only problem is cost as it gets expensive to the point that you may wonder why you didnt just whack a 20vt in there if its figures you are after.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #15 on: 25 July 2011, 12:42 »
See thats the thing you really have to weigh up cost.. TB's doing a good setup is a lot of money.. 20vt's are going for very cheap sub £500 for a full engine and box etc without galactic mileage.. im really considering TB's but am really going to have to weigh up other possibilities..
Offline frenchboy
« Reply #16 on: 25 July 2011, 14:47 »
Nice to see a good debate going on :grin:
For starters you mustn't of owned a car with twin 45s on it before :smug:
If I wanted to put a VR6 engine in then I would of just gone and bought a VR6 in the first place :laugh:
I personally don't see how you reckon that carbs are less performance and the cars I have had with twin 40s on before were very useable and didn't do that bad on fuel and at the mo my 16v is sh!te on fuel anyway so anything would be a vast improvement :laugh:
French small roads are great fun and empty so just looking for something that puts a smile on my face put personally I would prefer the sound from a very well set up set of twin 45s :evil:
Well I think twin 45s will be the way I am going to go matched with some head work and a set of cams,and I will also be fitting some bigger brakes as I agree with DOA.
Another question now I saw a camshaft maker saying that you only change 1 cam I think it was Catcams that say it so is this true?
  • Opinions я Us
« Reply #17 on: 25 July 2011, 19:05 »
I've been in plenty of grunty carb-fed cars.  They're not all that.
In preference to carbs, yes.  :grin: :grin:
Fact of the matter is that over any of the suggestions so far I would (:grin:).... no prizes for guessing..... do none of them and put an ABF on OEM management in it!  Thing is you'd get 165-175bhp with a tubular manifold on the back of it (and I hate to say it, but my experience says it's true) and an inlet kit.  This would definitely get a good noise, excellent reliability and bloody good economy over the solutions suggested on here so far.
The guy's looking at doing a couple of options that involve quite a lot of expense and are a 'project'.  Fitting up an ABF on OEM management isn't *that* much of a project, although it will probably get the next best result after ITBs for performance, for the lowest budget out of all of the options.
Depends what the car's for.  For track days and motorsport I'd definitely go for the ITB set up over the turbo set up, because I favour having a high-revving NA motor over all the torque of the turbo set up.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #18 on: 25 July 2011, 23:19 »
On the throttle body kit badger5 say 200bhp on the abf is possible is this true and what other supporting mods would be needed ?? I would prefer a good revvy engine for if I go on the track but decent mpg for if im going to a show and such..
Offline danny_p
« Reply #19 on: 25 July 2011, 23:54 »
200 bhp from an ITB'ed abf  - yup   lots of people have done it.
£100 of machene work to tri cut the valve seats and valves and 2 evenings work with a £30 mini die grinder and abour £30 worth of bits.
i would go as far as saying it'd be possible on std cams with good headwork  if i chould be arsed to prove it, its deantly possible with modifyed std cams and diy headwok
all the VW's have gone bar 1.
