Author Topic: The Datsun 240Z Build Thread  (Read 73550 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: The Datsun 240Z Build Thread
« Reply #110 on: 28 July 2012, 20:49 »
What spec are you building the cage to Dan ?
Offline IbanezDan51
« Reply #111 on: 30 July 2012, 08:37 »
Drag racing! This cage will be good for 9.99 seconds or quicker (down to 8.5 I believe) if I have the correct requirements elsewhere in the car which I wont as I dont realy ever intend running that quick - but it's there if I do.
Everything on the car will be spec'd for down to a 10 second car:
10.99 1/4-mile (6.99 1/8-mile) or quicker:
-5-point roll bar is still okay to 10.00 1/4-mile (6.40 1/8-mile) in hardtop / t-top with un-altered floors, firewall and frame rails (wheel tubs are okay). If the floor and/or firewall has been modified, then a full roll cage is required beginning at a 10.99 e.t. or any vehicle running 135 mph or faster (regardless of e.t.). The roll cage must be constructed of a minimum o.d. mild steel or chrome moly tubing (moly can be a smaller o.d and is lighter but more expensive), see diagram below for specs. Roll cage must be padded anywhere the driver's helmet may contact it while in the driving position, see diagram below for specs.
-Convertibles require full roll cage at 10.99 and quicker.
See diagram below.
-aftermarket axles with positive retention (c-clip eliminators)
-Transmission shield SFI Spec 4.1 at 10.99 and quicker or 135 mph and quicker (blanket is okay, no expiration date)
-Harmonic Balancer SFI Spec 18.1 (no expiration date)
Not sure how I get around the aftermarket axles - I already will have non genuine but I will need to look in to it a bit more! Wont be competitively racign for soem time yet though!
The cage should also pass most FIA regulations too I think.
Offline Len
« Reply #112 on: 31 July 2012, 08:19 »
Need any pit crew? :wink: :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline IbanezDan51
« Reply #113 on: 19 April 2013, 10:43 »
Wow I've not updated this for awhile...quite a few changes  :tongue:
Offline Len
« Reply #114 on: 19 April 2013, 12:19 »
It is about time Dan! :whistle:
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #115 on: 20 May 2013, 22:11 »
come on then
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #116 on: 30 May 2013, 18:27 »
This is coming along really nice been keeping updated with Facebook as ever and need a road trip to yours soon for some chevelle love and datsun love
Offline IbanezDan51
« Reply #117 on: 07 August 2013, 12:57 »
Just going to skip straight past a load of the build ... if you want to have a read please go to ukmkivs.
Managed to get the car on wheels at last and roll it outside to give the workshop a clean out...
Moved it back in...waiting for the engine and gearbox to be placed in now and mounts made up...
Reluctantly then started to take the engine out of the Camaro - was an absolute blast to drive around for a month in. Honestly - these do handle pretty well in standard form considering its 14 years old! Thanks to the besties for helping out this day... Impossible job to be done on its own. You literally have to take the engine and gearbox out with the cradle whilst the car is in the air - the cars are built around the engine...stupid design and poor engineering..
Then it was time to start on the wiring loom. Lots I didnt need with my conversion so pulled the whole lot apart and cut out all the bits I didn't need....quite a lot of wiring can be thrown away...
Once I had cut it out I could drape it around the engine to get it roughly how I wanted...
To be able to start and run the engine I needed to disable VATS (known to us english folk as the immobiliser system). This is a bit of a trick really, you can either buy a $700 program to do it or a small black box that does the trick...fortunately for me someone had already bought one of those box's in american and decided to strip it down... so I nipped to Maplins...bought all the parts and made my own...
I could then...start the engine [;)]
All my parts ordered yesterday (gearbox/flywheel/fuel pump/mastercylinder etc) but the clutch was on backorder so got to wait a wee bit longer for that...Hopefully will have everything but that next Tuesday... so can get mocking up in the car.
Dan
Offline Sam
  • Sam I am
« Reply #118 on: 07 August 2013, 17:52 »
Shizer that's looking great!
Offline Jack3559
« Reply #119 on: 07 August 2013, 23:13 »
That is stunning.
Incredible work.
It's making me weep.
