Golf mk2
8v GTI - won't turn over.
Topic: 8v GTI - won't turn over. (Read 3085 times)
Sam
Sam I am
Re: 8v GTI - won't turn over.
Reply #10 on:
20 July 2011, 20:27 »
Quote from: jmsheahan on 20 July 2011, 20:23
Fired up straight away with that trick.
Well then, with ignition on test the main live and neg cable with your multimeter and make sure it is 12v. Then make sure there is 12v comming from the engage switch (the thing that you put a wire to) and pretty soon you will have an idea of what is f**ked. You need somone to be actually trying to start the car when testing the engaging 12v
mk2bal
Reply #11 on:
20 July 2011, 20:55 »
Yep, as above its your switch or wiring to/from it
jmsheahan
Reply #12 on:
20 July 2011, 21:28 »
My voltmeter is a piece of crap (going to borrow a proper one from my mate tomorrow) but from what I could gather the starter is getter 12.5V but as soon as you try to start the car it drops significantly. Will get readings tomorrow!
jmsheahan
Reply #13 on:
22 July 2011, 10:13 »
Sorted - dodgy crimp on one of the battery wires. Thanks for the help
Golf mk2
