Author Topic: Another 'wont start' thread  (Read 2750 times)
Offline mk2bal
Re: Another 'wont start' thread
« Reply #10 on: 19 July 2011, 19:21 »
Well go back to basics,starting with timing, working your way through everything. There's tests possible for every check you have to do, to indicate correct function or fault
Offline emery1990
« Reply #11 on: 19 July 2011, 19:42 »
Could the starter motor falling of caused timing to go haywire. As mkbal said I'd start with that first, I spent week trying to start mine and it was timing and coil in the end.
Offline Sam
  • Sam I am
« Reply #12 on: 19 July 2011, 22:47 »
I dont see how that could happen though, surely the flywheel is bolted to the crank, in turn crank pully and thus cam pully and without the timing belt snapping nothing will have happened. There is no way it can be out!?
