Author Topic: Auxiliary Heater  (Read 31324 times)
Offline Keithuk
Re: Auxiliary Heater
« Reply #20 on: 18 August 2011, 12:06 »
If its that cold you would have a block heater that you plug into the electrical supply I think these are standard in Canada?
Auxillary air heater
Do the 2010 Golfs have engine block heater?
Yes I've seen Aux Heater in Measuring Blocks and component test the same as Doc but again it won't test if its not fitted?
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #21 on: 29 August 2011, 18:22 »
Current Garage:
35+ years of GTI ownership.
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #22 on: 29 August 2011, 21:17 »
So we talking about this heater  :sad:
http://www.golfmkv.com/forums/showthread.php?t=113468
Yup thats the one - hot air in no time ;-)
Should I go out in the cold and VAG COM mine......
Offline The Doc
« Reply #23 on: 15 October 2011, 20:13 »
Finally looked this up on my vagcom.
Car was cold and had climate set to auto and temp was set to 21oC
Ignition on:
Upon starting the engine:
Then a few seconds later:
Next is with the widscreen heating program selected:
Next I pressed the "OFF" button on the climate control - it turned off the aux heater:
