Author Topic: What's you local Shell charge per litre of Optimax?  (Read 9197 times)
kingsmk2
Re: What's you local Shell charge per litre of Optimax?
« Reply #30 on: 20 April 2005, 22:23 »
2 camels and 3bits of silver
Offline hockeylad72
« Reply #31 on: 20 April 2005, 23:16 »
just found a thread in another forum,
shell are going to replace optimax with a product called v power and it is 100RON!!!! apparently will cost the same as optimax.
don't know how reliable this info is tho
has enybodyelse heard about this????
Offline rtking449
  • Run out Mk2 8v GTI &MkIV Tornado Red GTI
« Reply #32 on: 22 April 2005, 23:52 »
90.9 Leyland,Lancashire
Offline Organisys
  • Old and Slow...
« Reply #33 on: 05 July 2005, 20:05 »
As far as I can tell, V-Power is only available in the US. Note that the UK and US use a different unit of measurement for knock Resistance (RON and DON).
http://en.wikipedia.org/wiki/Petrol#Octane_rating
Note that filling up with 100 RON petrol if we ever get it, WILL NOT make your car perform better, unless the engine was designed for it.
the RON rating is a measure of the fuels ability to resist pre-ignition due to combustion. NOT the amount of power available from burning.
Offline gstar-dubworld
  • Here comes the piano man - his a peaceful man..
« Reply #34 on: 06 July 2005, 02:15 »
The city of round-abouts is selling it at 92.9p - I am thinking of buying some shares in Shell in order gain some return with all the Shell users here onboard  :smiley:
Offline gibby
« Reply #35 on: 06 July 2005, 08:33 »
Even t'up north the price is a rip off, filled up last night, 91.9p a litre ! WTF ! At least Dick Turpin wore a mask eh !  :angry: You know it's getting bad when the price display on the pump nearly goes round as fast as the litre display.  :angry: If this was the USA there would be out and out anarchy, they get pissed off when they pay 35c a litre or something.  :angry: Rant over.  :smiley:
......now officially dubless.
Offline hachi-roku
« Reply #36 on: 06 July 2005, 12:47 »
89.9p in Norwich.
I always used Optimax for my S13 due to it being a turbo and slightly fettled... without it, I'd get det and thats not good :(
on the Golf I can't see why optimax would make a difference unless you altered the timing to suit it?  :undecided:
Offline mjamoose
  • I'm off a hunting! (for a head gasket)
« Reply #37 on: 06 July 2005, 12:55 »
It's about 98.9 In Reading.  TBH my car runs well enough on 95RON BP (Standard unleaded) and being a 1.6 carb engine I don't see much reason in using optimax or ultimate.
WARNING DRUMMER ON THE LOOSE :evil:
Offline gibby
« Reply #38 on: 06 July 2005, 14:19 »
Don't know if applicable to digi's, but it's reckoned that K-Jet engines should run on a higher RON.
Offline hachi-roku
« Reply #39 on: 06 July 2005, 14:27 »
Ahh, that would make some sence then :)
I know optimax is a better quality of fuel, so either way it's nicer to use :) I had a Mk1 MR2 wich I altered the timing for optimax, seemed a little bit more responsive, but not enough to really go through the hassle again :)
