Author Topic: Dom's Mk4 Story So Far - it's all over!  (Read 439254 times)
Offline SoundillusioN
Re: Dom069 - My Mk4 Story So Far, Water Leak Hunting
« Reply #210 on: 19 August 2011, 10:21 »
Missed all your updates... shame you've had to hunt down leaks already.... at least you seem to have sorted it now... I think I've found mine............ eveyfeckingwhere!
Well re-sealing the vents did not solve the problem, stripped the rear out again this evening and got the pressure washer on it. Water is p!ssing in through the boot seal along the bottom of the boot, especially the n/s. It looks like the back panel is sitting too far into the boot so the seal isn't being made correctly when the boot is closed :rolleyes:
Going to take a sledgehammer to it on Sunday to see if I can knock it back out, got a panel beater mate coming over to help out so hopefully problem will be solved soon :smiley:
What a pain in the ass!... I have similar issues with mine!..
« Reply #211 on: 19 August 2011, 10:42 »
Good luck with sorting it Dom.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #212 on: 19 August 2011, 12:05 »
of the 3 mk4's we have had, all of them leaked in.. more so when a jet wash was used..
 hope you get this  minor set back sorted quick  :smiley: :cool:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline dom
  • Back in a Mk4
« Reply #213 on: 21 August 2011, 13:26 »
My day so far has consisted of lots of hammering, swearing and inhaling fumes and the car now stands like this:
The back panel is now sitting where it should and creates a tight seal with the boot lid, the surrounding panels have also been corrected to ensure the n/s light not sits correctly and a few other dents have been pulled out. We then water tested the car to ensure it was watertight, which it appears to be :smiley:
Every seam which provides the slightest opportunity to allow water through has been coated in a professional grade sealant which is drying as I type. In a few hours this will be painted and the car will be pieced back together.
Fingers crossed it will not be letting any more water in :smiley:
« Reply #214 on: 21 August 2011, 17:11 »
Hope it has fixed it Dom :afro:
Offline dom
  • Back in a Mk4
« Reply #215 on: 21 August 2011, 18:03 »
Ok, so the car is pieced back together with the sealant painted black :smiley:
I have also removed the front mud flaps and replaced the standard side light bulbs with some bright LED's instead:
What a hell of a job to change some bulbs! Had to remove the bumpers :angry:
Also the engine is sounding as rough as a dog :sick:
I've uploaded a video here.
Is number 1 the fuel pressure regulator? Number 2 the fuel pressure rail? It seems to be coming from there :undecided:
Offline Dmonday
« Reply #216 on: 21 August 2011, 18:27 »
My friends 1.8T sounds like that, but i don't really like him so haven't looked into it :D hopefully isn't a massive fix :)
Offline dom
  • Back in a Mk4
« Reply #217 on: 21 August 2011, 18:32 »
 :grin: Get yourself over to his and fix it so you can let me know what I need to do!
« Reply #218 on: 21 August 2011, 19:07 »
Hard to tell from video but does not sound right, how does it drive.
Offline dom
  • Back in a Mk4
« Reply #219 on: 21 August 2011, 19:10 »
On the whole it drives ok, idle can be slightly erratic though and power can often surge between 2-3k rpm on half throttle :undecided:
