Author Topic: Wheel Advice  (Read 3041 times)
Offline Len
Re: Wheel Advice
« Reply #10 on: 08 July 2011, 10:01 »
Max size is 17x8 with 215/40 tyres.
www.sas.org.uk
www.the-ace.org.uk
Offline nightroamer
  • Mk3 16v
Re: Wheel Advice
« Reply #11 on: 08 July 2011, 10:05 »
16" with 195 or 205/45's is a good choice :afro:
Wayne how wide should I go in inches and what sort of offset don't want any rubbing if possible.
Offline Jack3559
Re: Wheel Advice
« Reply #12 on: 08 July 2011, 10:13 »
Lowest offset you can realistically do at the front is ET25, rear ET15... lower if you shove a camber shim in there.
Re: Wheel Advice
« Reply #13 on: 08 July 2011, 10:49 »
Et30 or 25 is a good choice  :smiley:
Offline nightroamer
  • Mk3 16v
Re: Wheel Advice
« Reply #14 on: 08 July 2011, 12:52 »
Would the Vintage Calibre 17x8's be ok? cant find the offset?
Has anyone fitted them? can i lower a little still?
Re: Wheel Advice
« Reply #15 on: 08 July 2011, 12:56 »
Yep 205/40/17's tyres are what you need, I ran the same size with a 45mm drop all ok.
Offline MK4D4VE
Re: Wheel Advice
« Reply #16 on: 08 July 2011, 12:58 »
I believe ET32 is the Vintage offset, they sit pretty much flush with the arch, so you can either run stretched tyres or roll the arch, althought the rubbing without arch roll is minimum - depends how slammed you want it to be.
Golf MK4 1.8 20v GTI
Offline nightroamer
  • Mk3 16v
Re: Wheel Advice
« Reply #17 on: 08 July 2011, 13:07 »
Cool thanks everyone, pretty much set on these now.
Prob run them at standard height then sort some coil overs.
Re: Wheel Advice
« Reply #18 on: 08 July 2011, 13:28 »
Offline nightroamer
  • Mk3 16v
Re: Wheel Advice
« Reply #19 on: 08 July 2011, 13:32 »
16" http://www.bmautosport.co.uk/detail.php?siteid=2074
:afro:
Now your just being naughty Wayne!
They look gorgeous, what does he mean by double drilled?
Would an 8" with et20 fit front and a 9" et25 rear?
