Author Topic: Connects2 / MFSW / Highline  (Read 2188 times)
Offline Kwok8
« on: 06 July 2011, 13:37 »
Anyone have any experience with the Connects2 and getting it to work with the buttons on the multifunctional steering wheel and getting the information to display on the Highline?
I installed the Motorola TK-30 with Connects 2 module at the weekend, works fine but can't make use of the phone button and highline screen.
Supposedly I can also control the music from the steering wheel via bluetooth and titles display on on-board computer.
I tried activating the Telephone (77) from Vagcom, but it just errors. If I scroll through my options on the on-board computer, it just says Motorola TK-30.
Am I missing a trick?
Offline DaveN
Re: Connects2 / MFSW / Highline
« Reply #1 on: 07 July 2011, 09:08 »
I have a quickconnectproducts.com harness for my parrot and I recall I had to use vag-com to go in to the steering wheel module and change the configuration to enable the phone button.
I think the worst time to have a heart attack is during a game of charades. Especially if your teammates are bad guessers.
Offline Kwok8
« Reply #2 on: 07 July 2011, 12:15 »
Dave, you don't recall where it was do you?
Offline DaveN
« Reply #3 on: 08 July 2011, 17:11 »
I'll have a look at the weekend, Its in the control module for the steering in VAG-COM if you hold the cursor over the coding a helper appears showing the code options. Something like below;
; coding
C00,Steering Wheel Electronics (J527) Coding
C01,0?xxxxx: Vehicle Type
C02,0 = Normal / 1 = Special Purpose (e.g Taxi)
C03,0x?xxxx: Transmission
C04,0 = Manual Transmission
C05,1 = Automatic Transmission
C06,0xx?xxx: Steering Wheel
C07,0 = Steering Wheel without Multifunction
C08,1 = 3-Spoke Steering Wheel without Multifunction
C09,2 = 3/4-Spoke Steering Wheel with Multifunction without Cruise & Voice Control
C10,3 = 3/4-Spoke Steering Wheel with Multifunction with Cruise & Voice Control
C11,0xxx?xx: Additional Equipment
C12,+1 = Tiptronic (Shift Paddels)
C13,0xxxx?x: Board Computer / Cruise Control System (CCS)
C14,0 = w/o Board Computer and w/o Cruise Control System (CCS)
C15,1 = with Board Computer and w/o Cruise Control System (CCS)
C16,2 = w/o Board Computer and with Cruise Control System (CCS)
C17,4 = with Board Computer and with Cruise Control System (CCS)
C18,0xxxxx?: Rear Wiper
C19,1 = Rear Wiper not installed
C20,2 = Rear Wiper installed
Offline DaveN
« Reply #4 on: 08 July 2011, 17:13 »
I used http://uk-mkivs.net/forums/t/156872.aspx when installing my multifunction buttons so it may help.
