Author Topic: She wont start  (Read 5641 times)
Offline Sam
  • Sam I am
Re: She wont start
« Reply #10 on: 07 July 2011, 12:41 »
Ok, presume I flooded her the other night. Anyhow now I have the issue of she will start first time but if I dont rev her straight away and she dies I cannot start her again (unless I bump her). Any thoughts?
And it'll start every time if you do a rolling bump?  :shocked:
Yerp  :evil:
How well does it run/drive when it is fired up?
Fine, it idles a bit weird somtimes but thats about it. Dont know if the dizzy needs a twist or somthing but dont really wanna touch it whilst its running.
Offline SoundillusioN
Re: She wont start
« Reply #11 on: 07 July 2011, 13:00 »
Yerp  :evil:
Might be worth checking everything against the timing marks though.
Offline gibby
Re: She wont start
« Reply #12 on: 09 July 2011, 12:58 »
....this may not fix this issue but while you're doing a few bits I'd also advise that you find the fuel pump relay, take it out and get some sandpaper on the connections because a pound to a penny you'll have problems with this at some point. Do a search for fuel pump relay as I've done a few answers in this section with regards to that issue.
Reason I dont think it will help with this issue is that the fuel relay issue rears it's ugly head when the cars warm. It did make my old cab cut out while actually driving once and that was quite hairy.
......now officially dubless.
