Author Topic: Fuel filter  (Read 2731 times)
Offline kevin31
Fuel filter
« on: 05 July 2011, 07:29 »
Hey guys
Well one thing that came out of my remap at weekend is the need for the fuel filter to be changed! Anyone got some pics of where it is or a guide to changing it please?
Still can't get over the difference the remap has made the car is awesome! Relly feel the power at about 3000 rpm!
Kev
1999 Golf GTI MkIV 1.8T 20V AGU
Offline snifferdog
Re: Fuel filter
« Reply #1 on: 05 July 2011, 07:31 »
It's apparently very easy to change, a 5 minute job. Do a search, this gets asked a lot. I'm on my phone so can't help.
Offline Dave_IOW
Re: Fuel filter
« Reply #2 on: 05 July 2011, 07:32 »
Fuel filter is under your petrol tank, jack your car up and have a look behind your drivers side rear wheel and you will see it, easy job   :afro:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline kevin31
Re: Fuel filter
« Reply #3 on: 05 July 2011, 07:40 »
Thanks have searched only found this but no pics
http://forums.vwvortex.com/showthread.php?1276409
This says it's not under drivers side rear wheel?
Where best place to buy? Is it here http://www.vwspares.co.uk/g2filters.php
Kev
Offline Dave_IOW
Re: Fuel filter
« Reply #4 on: 05 July 2011, 17:19 »
Well its not directly there but you WILL see it, look from under the sill, cant miss it.. its silver  :wink:
Offline uncleben
Re: Fuel filter
« Reply #5 on: 05 July 2011, 19:38 »
that guide on vw vortex is american, hence why they state the filter is behind the PASSENGER wheel!! if mk4's are anything like my mk2 gti then it really is easy, just changed mine! just note there will be lots of high pressure fuel which will run all down your arms and possibly your armpits so work quickly!!
Re: Fuel filter
« Reply #6 on: 06 July 2011, 00:16 »
You should remove the fuse for the fuel pump, then run the car until it stops this lets the pressure out of the system then you ok to replace the filter. :smiley:
Offline Phil18t
Re: Fuel filter
« Reply #7 on: 06 July 2011, 22:29 »
just make sure you close your eyes when you pull the pipes off... :smiley:
Re: Fuel filter
« Reply #8 on: 06 July 2011, 23:40 »
Or wear safety goggles  :smiley:
In any case with the system depressured it should not pump out.
Offline Dave_IOW
Re: Fuel filter
« Reply #9 on: 07 July 2011, 18:23 »
Are you a health and safety executive Wayne  :laugh:
I would never been seen in safety gogs  :grin:
You could always make your own   :huh:
