Author Topic: gues the part  (Read 5653 times)
Offline SoundillusioN
Re: gues the part
« Reply #10 on: 04 July 2011, 12:22 »
EErrrrmmm N249 black plastic thing ontop od coil 4 and its now by the battery  ?  ?
This isn't as much fun as guess the engine....
think you need to give us a before pic....
+1
+98
although I think it might be the sump nut  :smiley:
How on earth do you relocate a sump nut!?  :grin:
Re: gues the part
« Reply #11 on: 04 July 2011, 12:26 »
Thanks to Guy I looked at this...
what's that thing above your 4th coil pack?  :rolleyes:
Offline StusDUB
Re: gues the part
« Reply #12 on: 04 July 2011, 12:27 »
check my post on page 1  :tongue:
Offline StusDUB
Re: gues the part
« Reply #13 on: 04 July 2011, 12:27 »
its been relocated to the side of the batt  :cool: :laugh:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: gues the part
« Reply #14 on: 04 July 2011, 12:30 »
N249 ?
mine got relocated to the garage in a cardoard box  :grin:
Not no ordinary GTI....
www.mixcloud.com/kells/
Re: gues the part
« Reply #15 on: 04 July 2011, 12:30 »
Damn you must be bored today.  :grin:
What is it anyway?
Offline StusDUB
Re: gues the part
« Reply #16 on: 04 July 2011, 12:32 »
What is it anyway?
lol
Its like a Vac reservoir for the N249 only recognised it as did the N249 delete at the weekend lol  :laugh:
Offline Rhyso
Re: gues the part
« Reply #17 on: 04 July 2011, 12:32 »
What is it anyway?
Part of the sh!t that VW fitted to the later 1.8T engines
Copied from a thread on Seat Cupra
N249 is controlling the DV (Dump Valve). It is installed between the intake vacuum source and DV itself. When no current is switched to the N249 (default state), the DV will get vacuum or boost from the intake manifold. This is how almost ALL turbo cars are worknig. When shifting gears, you let off throttle, TB closes and vacuum is generated which can open DV to vent boost (which cannot enter engine, because TB is closed).
On never 1.8Ts (2000+) they introduced the N249 (along with lots of other stuff) which is a possibility for the ECU to open the DV any time (!), even during full throttle/acceleration. When the engine is running and turbo is boosting, there is no vacuum generated, but to open the DV (which is mechanical), vacuum is needed. This is what the black vacuum reservior on top of the engine is used for. When idling, shifting, etc - so when vacuum is available, vacuum is led into this reservoir from the intake manifold and kept inside using a check valve (white/black), so when boosting again, vacuum will stay there (air cannot enter into the reservoir).
When ECU wants to open DV durnig full throttle/acceleration, simply "energizes" N249, which will "de-select" the DV from the intake manifold (boost), and "switches" it onto the vacuum reservior. The vacuum in the reservoir will open the DV instantly and release your boost, which, in most of the cases (tuning, etc) is not that highly required . In the case ECU sees a little overboost problem, it can turn N249 on/off repeatedly for very fast (just as N75 is working), which will open/close DV all the time, trying to settle (lower) the boost level.
PROs: By removing N249 valve, you can prevent this bad habit of the ECU, and by removing N249 valve, you are removing an approximately 2mm narrow bottle neck restriction (ID of the N249 valve) in the line to the DV, which will result in a somewhat faster DV response. I am using the stock bosch DV, but it feels just as good as an aftermarket DV with N249 (restriction) inline. Boost curve is smooth and progressive.
CONs: Boost overshots/spikes may grow higher, especially in high gear/low rpm situations (using the small K03), which can result in a leaner condition (for the moment). These spikes depend on N75 type, wastegate setting and software programming, but they usually don't last long (0.5-1s max). In the case these spikes are very high (car enters limp even), minor adjustment on the wastegate can be done. Ibiza engine covers cannot be used anymore (by removing the accessories above, two mounting points of the cover are removed aswell).
Offline Guy
Re: gues the part
« Reply #18 on: 04 July 2011, 12:37 »
+1
+98
i was being ironic... how would we have spotted it anyway?  :grin:
well i glad this is sorted... can we get back to guessing engines please?  :smiley:
Offline Guy
Re: gues the part
« Reply #19 on: 04 July 2011, 12:39 »
this is the winner.. but the answer should have been confirmed much earlier  :rolleyes:
