Author Topic: t4 turbo, is this kit any good ?  (Read 19314 times)
Offline golf-sib
  • Турботазик
Re: t4 turbo, is this kit any good ?
« Reply #50 on: 05 July 2011, 18:03 »
Sounds interesting, definitely will head down the t3/4 route.
Regarding water injection, any kits you recommend, as some information may give me an idea on possibly doing this in the future.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Dave_IOW
« Reply #51 on: 05 July 2011, 19:34 »
Interesting thing with the downpipe, T3/4 exhausts at the top i think, not sure if you can get these any cheaper anywhere..
Pressume you would only need the 'U' bend  :rolleyes:
http://www.gt3turbo.com/Merchant/product.php?productid=730&cat=409&page=1
« Last Edit: 05 July 2011, 20:31 by Dave_IOW »
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #52 on: 05 July 2011, 19:39 »
@ Houston
Not going to tell the exact spec yet, as I have spent the last four month working on the turbo. I found not all parts are equal even in ko3s parts vary between batches.  It's basically the aggressive turbine side from the k04-001,  with one of the bigger comp wheels from a ko3s, plus machine work on the comp housing, wastegate and back plate. There is another generation comp wheel that I am going to try just to see if I can loose a more low down torque and give a even greater area under the curve at the top end.
As for clutch I am running the stock oem dmf and clutch set up, so cannot comment on the vr6 solid setup, but I have known the solid conversion to suffer with stage2 ko3s mapping in the past, but never looked in to why it was slipping under load. You need to do some research on the solid setup and see what people are actually pushing from them and where the peak torque is rpm wise.
 01455 617233
Offline golf-sib
  • Турботазик
« Reply #53 on: 05 July 2011, 20:05 »
vr6 clutch slipping... first I've heard of it, why is it such a popular conversion as I thought the DMF wasn't that durable and the figures of the vr6 clutch where superior. Be good to find out more about this as I think this would be a shocker.
All interesting and first I have heard of it.
Alse here's your pics:
1.8T AGU..
R135
  24
Offline RTechUK
« Reply #54 on: 05 July 2011, 20:18 »
Cheers for adding the pics.
As for the solid conversion that was slipping we never found out what kit was used, oem, 3rd party or eBay solid deal kit. So I cannot comment on it until I actually use one or map an oem kit with big power.  It's the low down torque where the clutch suffers slip. I know the cheap dmf kits from CAS slip with 225lbft straight out the box. My next clutch setup will be sachs fast road organic clutch with oem dmf
 01455 617233
Offline golf-sib
  • Турботазик
« Reply #55 on: 05 July 2011, 20:31 »
Be good to know your findings as I am on the sachs vr6 clutch and ecs 14lb flywheel.
Any info on meth/water kits you guys running and are they easy to install and how do they operate (as in are they like a carburetor where as air flow increases so does the water, or is it managed by a separate unit that takes a reading etc?).
« Last Edit: 07 July 2011, 19:37 by golf-sib »
1.8T AGU..
R135
  24
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #56 on: 05 July 2011, 21:49 »
The kit I had in mind to make had a pressure switch in the inlet which activates a washer bottle motor. then the water is fed to a nozzle that injects the water as a mist... The Renault 5 GT turbo has an adjustable pressure switch on it that can be used
Offline richw911
« Reply #57 on: 05 July 2011, 22:13 »
Most things we buy nowadays are made in china arent they?? they all have to be made to a decent quality for people to be able to sell them dont they.. you cant sell something that is going to blow when you push it to the quoted figures they have provided?  :undecided:
No steer clear imo
Have you have tried and tested one?
We have tried and tested many cheap turbos from ebay, xs-power ssautochrome and all made good power and lasted the duration. One was a T34/s5 running at 508bhp@1.7bar another 1.5bar 470bhp,  T3/04e 404bhp@1.7bar(£140 turbo from ebay)  k04-001 240bhp.
Its down to how they are tuned and heat generation, and even if it blows in the 1st year its only going to cost £140 for a new one, and not £1k+ for a oem.
Done right they are worth the money IMHO. :smiley:
No i have not BUT i have always been told, by everyone ive ever spoken to avoid Chinese turbos. Its not a route i would go down i want reliability and piece of mind - that's just my opinion.
But hay if you have tested them and say they are ok then go for it people  :smiley:
« Last Edit: 05 July 2011, 22:15 by richw911 »
Offline houston
« Reply #58 on: 05 July 2011, 22:20 »
No steer clear imo
like i said, the people who buy the cheap turbos usually buy other bits on the cheap, if a turbo goes pop theres most likely an underlying cause. also even oe turbos go pop
Offline RTechUK
« Reply #59 on: 05 July 2011, 22:21 »
Devils own stage 2 kit is the one I use, google it.  Water injection needs to be mapped correct, Ie lean running fuel map strategy more ignition advance at peak cylinder pressure.  Running the fuel at stage 2 or even stage1 12.5:1 / 11.5:1 will reduce power, but still give good cooling.   I am running 13.5:1 under load from 3000rpm to 7800rpm with around 4deg more advance than any other mapped 1.8t would run. I am seeing ignition pull of 4-5cf at 3500rpm at 22psi, without the water injection the Ignition correction would be pulling +12cf, with loud audible knock/pinking and on the verge of piston or spark plug damage.  I can thrash my car hard for 3 hours, then straight away lift the bonnet and put my face on the inlet manifold which will be as cold as a can of beef of of the fridge.
We also used it on a mondeo tdci with nos and managed over 100bhp 130lbft gains on the stock turbo, it's the water injection which maintained the power across the whole rpm range.  Should be in the fast ford mag soon, once if the quickest 130tdci in the uk. :-)
 01455 617233
