Author Topic: t4 turbo, is this kit any good ?  (Read 19339 times)
Offline lord14
Re: t4 turbo, is this kit any good ?
« Reply #20 on: 03 July 2011, 23:34 »
well my brother has done the conversion , and spoke to many tuning companys and they've all said the same thing , we use 3 bar fuel reg's and a bigger fuel pump , 440cc injectors , 3 inch maf , 2.5inch downpipe , no oil cooler , forged pistons and rods with , t3/t4 turbo , and mapped by rtech made 404bhp and its realiable drive it to work most days . but im not sure what bottom end you have but i know the agu has been proven up to 350bhp by jabba sport and boost pipes we use 2.25 inch
Offline Dave_IOW
« Reply #21 on: 03 July 2011, 23:39 »
i got 2.5 FMIC anyways so thats all set up, uprated pump will be 255lph walbro (in pipeline), 4BFPR cheap enough to get, could get a T3 flange welded onto that 3'' system i have, then 3'' TIP (should be easy enough)..
Bad ideas to be getting in my head, thought id be happy at 240   :rolleyes:
Would be aiming just under 300 to keep bottom end standard..
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline lord14
« Reply #22 on: 03 July 2011, 23:42 »
sounds about right , but i would stick with the 3bar fuel reg
Offline golf-sib
  • Турботазик
« Reply #23 on: 03 July 2011, 23:48 »
Dave, another PM your way, plus you know you wont be happy till theres 1000lb off torque  :grin: :grin: :grin: :grin: :grin:
Also whats the whole issue regarding the FBR, I usually have seen 4FBR or adjustable FBR's used in these setups.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline lord14
« Reply #24 on: 03 July 2011, 23:53 »
just alot of mapping places say use a 3fbr as the the bigger ones arent needed .unless going for massive power , jabba sport , rtech and sub 11 motorsport have all said the same sort of thing about everythink including the bottom end , i know on a agu its possible of up to 320 bhp at 17psi on standard pistons and rods ;)
Offline golf-sib
  • Турботазик
« Reply #25 on: 04 July 2011, 00:01 »
I remember the max boost is recommended at 20.58 psi, a lot of places allow a quick 21 spike or lower/restrict spike with MBC in parallel to n75 from what I remember on the stock engine.
1.8T AGU..
R135
  24
Offline lord14
« Reply #26 on: 04 July 2011, 00:06 »
yeh i know the mbc's aren't very good on the 1.8t's i seemed to of got alot of boost spiking , but with a aem boost controller its great the mapping was alot easier aswell . and alot quicker , and n75 i know they  can be mapped but personally i would get  a ebc so you can go into different modes with different boost settings and there is a over boost alarm
Offline Dave_IOW
« Reply #27 on: 04 July 2011, 20:58 »
going to start buying some bits to make this happen, oil line?
http://www.ebay.co.uk/itm/Garrett-T3-T4-T04B-T04E-Turbocharger-Turbo-Oil-Feed-Kit-/370523820981?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5644f0d3b5
Also another question, with an external wastegate, do you still have an actuator or is the external one opened with a seperate spring so doesnt need it? As the ones ive seen come with a 7psi/12psi/15psi spring etc so does this replace the need for the actuator itself?
If that is the case, where does the n75 outlet go to? A valve on the exterior wastegate?
Cheers   :laugh:
Offline golf-sib
  • Турботазик
« Reply #28 on: 04 July 2011, 21:37 »
Believe you don't need the actuator as the screamer acts like an atmospheric DV on the exhuast gases if my knowledge serves me correct, which allows the turbo to release and spool down.
I will be heading down this road after this gentleman's experience, especially once I get my MIG welder, think the complete kit works out cheaper dave, and you can claim some money back by selling the bits you don't need like the additional FMIC, Oil cooler (worth a bit) etc... Just an idea  :undecided:
1.8T AGU..
R135
  24
Offline Dave_IOW
« Reply #29 on: 04 July 2011, 21:46 »
What i was thinking tbh, once ive sold KO3s (£200ish) Forge actuator (£80?) and downpipe and sports cat (£100-£200) i should be well on the way without actually spending that much :smiley:
We need to talk about TIP's golf-sib  :wink:
