Author Topic: 1.2T !?  (Read 9112 times)
Offline cняis
Re: 1.2T !?
« Reply #30 on: 06 July 2011, 13:38 »
I think the analogy was between a 1.2T and other, larger capacity engines which require less thrashing to attain the same "flat out" speed/acceleration of a 1.2T.
Take for instance the Top Gear fuel economy test (although not scientific admittedly) between the Prius and an M3 (iirc) which depicted that the Prius aquired lower MPG whilst being thrashed compared the the M3 which had to keep up with it.
Offline Jack3559
Re: 1.2T !?
« Reply #31 on: 06 July 2011, 13:42 »
The 330d was more economical than the 320d for that reason.
Returned much better MPG because you barely needed to touch the throttle to go way faster than the 320d did when you were flooring it.
Offline AudiA8Quattro
Re: 1.2T !?
« Reply #32 on: 06 July 2011, 14:52 »
Either way a smaller engine will use less fuel, you're not going to put your foot to the floor from the moment you turn the key.
Offline Ess_Three
Re: 1.2T !?
« Reply #33 on: 06 July 2011, 15:01 »
Bingo! And a modern engine will always be more efficient than an old engine.
..but gaining motorcycles.
Offline Agreeable Slick
  • Unit
Re: 1.2T !?
« Reply #34 on: 06 July 2011, 15:23 »
we need 2  stroke diesels
obv with dcommon rail injection and plenty of boost
Like an old Dockers? :tongue:
Marine 2 strokes, now you're talking :grin:
Offline Jimp
Re: 1.2T !?
« Reply #35 on: 06 July 2011, 15:40 »
Never driven a 1.4 mk5 then?  :lipsrsealed: :grin:
Not low enough mk5
Not on the road enough mk3
