Author Topic: Revs randomly dropping to 0 when driving?  (Read 4119 times)
Offline javalin
Re: Revs randomly dropping to 0 when driving?
« Reply #10 on: 02 July 2011, 15:21 »
yeah a few people have had this recently, and the GSF sensor seems to be a decent bit of kit.  Got one in mine and its fine.
Good job.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline bmouthboyo
« Reply #11 on: 03 July 2011, 12:18 »
Does it take long to change? A quick read about and it mentions undoing engine mount bolts, gearbox supported with jack etc.
How does this compare to say head gasket job?
Offline javalin
« Reply #12 on: 03 July 2011, 12:25 »
not long.
From memory you need to take the front engine mount off - so support gearbox with jack.  Swap over sensor and re-fit mount.
Haynes manual if you are not sure.
100% easier.
James
Offline Gti Gerbil
« Reply #13 on: 03 July 2011, 14:05 »
took me about 20 mins to do
put front on ramps
battery earth off
undid bolt from mounting bracket to mount/body
trolly jack under gearbox and lifted slightly (about an inch)
undid mounting bracket
got the allen key bolt out of sensor and levered gently with a large screwdriver
refitted in reverse
no special tools needed but the allen key bit / holder on the end of a short extension bar made undoing the retaining bolt on the sensor pretty easy, might be a little harder with standard "L" shaped allen keys due to fairly tight access unless you remove the oil filter too.
find me on skype : paul.taylor.999 .. Vagcom reads for all, with a free cup of tea
Offline bmouthboyo
« Reply #14 on: 23 July 2011, 11:51 »
OK so I finally got around to testing the car fully with VAGCOM. Here are the results:
Chassis Type: 1H - VW G/J/V Mk3
Scan: 01,02,03,08,15,25,56
Address 01: Engine
Controller: 037 906 025 R
Component: SIMOS 4S 2104
Coding: 00000
Shop #: WSC 99999
1 Fault Found:
00513 - Engine Speed Sensor (G28)
16-10 - Signal Outside Specifications - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Controller: 3A0 907 379
Component: ABS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 00000
2 Faults Found:
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
35-00 - -
Skipping Address 15-Airbags
Address 25: Immobilizer
Controller: 1H0 953 257 B
Component: IMMO VWZ3Z0T1071555 V00
Coding: 09600
Shop #: WSC 00675
No fault code found.
End
Randomly I tried the scan again after a few times and it does not pick the 00513 - Engine Speed Sensor (G28) fault up?  :undecided: I am also confused as the speedo is working fine, its just the engine revs drop, the ECU relay clicks rapidly and lose power. Sometimes it starts straight after, others not for a while.
So I assume it's the crank sensor? I have had a poke about and I think this is the sensor? and the wiring seems damaged. Would this cause the problems I outlined at the start of the post?
Interestingly a fault I was getting about 8 months ago from VAGCOM about the Lambda sensor now does not show:
Should I still replace the Lambda also?
« Last Edit: 23 July 2011, 13:51 by bmouthboyo »
Offline Gti Gerbil
« Reply #15 on: 23 July 2011, 14:19 »
erm... hell yeah
thats the kiddie
changing that cured all my running problems
Offline bmouthboyo
« Reply #16 on: 23 July 2011, 15:28 »
erm... hell yeah
thats the kiddie
That sounds like good news. Not sure whether to repair the current wires or buy new?
I am not so confident removing engine mounts etc. Is it possible to remove and replace without doing this?
Offline Gti Gerbil
« Reply #17 on: 23 July 2011, 15:41 »
could try without taking mount out but it would be very difficult
as for repairing the wires, could try but while you got the sensor out may as well put a new one in as it could be the sensor its self and the wires are a secondary problem
Offline Seanl
« Reply #18 on: 23 July 2011, 20:02 »
Gonna be fitting a new lump on mine in the next couple of weeks, and the crank sensor on the old and new engine were split where you have shown, and by the sensor into the block itself. They were both very brittle on the insulation, and as soon as I disconnected them both, the flexing of the cable just made the wire start parting from the sensor causing the wires to short as both outer, and core insulation was fecked! IMHO I would replace it as it's most likely the same if still original.
Offline bmouthboyo
« Reply #19 on: 24 July 2011, 13:29 »
Yea good point, might as well replace it.
Is this the front engine mount? (sorry havnt played with mounts etc before)
