Author Topic: Correct wheel nut torque?  (Read 21145 times)
Offline p3asa
Re: Correct wheel nut torque?
« Reply #10 on: 25 June 2011, 10:22 »
.............. your not surposed to copper slip the wheel centres to stop them sticking to the hub as this will be a chemical reaction over time.
Really? Do you know what happens?  As this was the first thing I did with my wifes new car after I couldn't remove a wheel from my old car.
I had removed all the bolts but it was as if the alloy wheel had welded itself on to the hub. No amount of battering it would remove it.
It was a nightmare. I actually ended up super-gluing the puncture so I could at least drive the car to the tyre fitters and they removed it with a nice big sledge hammer!!!
Offline Keithuk
« Reply #11 on: 26 June 2011, 18:33 »
Yes you're not supposed to use copper slip but I do.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline p3asa
« Reply #12 on: 27 June 2011, 17:12 »
Keith I can understand why you're not meant to use copper slip on the bolts or nuts but why not on the hub?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #13 on: 27 June 2011, 17:54 »
Ive always used it on the wheel surface were it touches the hub.
A mate of mine has a unit were he keeps about 20 cars outside, the ones we don't do this too the wheel weld on solid due to the cemical reaction. The ones we do treat, even 10 years of untouched standing the wheels come off. 30 years of doing this it seems to works for us.  :undecided:
Why it may not work in theory would be interesting to know though.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Keithuk
« Reply #14 on: 28 June 2011, 12:44 »
Thats what the guys at work tell me, I've Googled it but I can't read a definate answer. VW say in the handbook don't lubricate the bolt threads and Autodata say this in what I posted the first time. I've always lubricated wheel bolts/nuts and wheel centres. The number of times I've had to use a mallet on the wheel to release it from the hub. If your worried about copper slip then just use an high melting point wheel bearing grease its just as good?
There is a chemical reaction between disimilar metals copper and aluminium over time.
e.g.
Some metals should not be mixed.....
Galvanic corrosion
Offline p3asa
« Reply #15 on: 28 June 2011, 19:52 »
Cheers Keith.
I'd rather put something on the hub than be stuck miles away from anywhere with a puncture and unable to get the wheel off.
My dad was a metallurgist so I'll see if he knows any better.
Offline CHB100
« Reply #16 on: 30 June 2011, 17:42 »
e.g.
Galvanic corrosion
I still use the copper slip acquired while working for Ken Tyrrell. If it's good enough for F1 it's good enough, full stop. Maybe if you intend to keep a car for say 50 years!!!!! But seriously I've used it since mid 80s and will continue to do so.
Arrived 15/5/17 Mk 7.5 R Lapiz 5dr DSG, Prets, Pan Roof, DCC, Rear View Cam.
Our other car is a Mk7 GTI DSG 5dr Tungsten, Vienna, Rear View Cam, Park assist.
