Author Topic: seized bottom ball joint bolt?  (Read 1273 times)
Offline Cory
« on: 19 June 2011, 10:06 »
what is says on the tin really. the nut come off the bolt really easy, but i spent an way over an hour
trying to get the bolt to move last night, and ended up admitting defeat after hitting my thumb with the hammer.
i was thinking of getting a blow torch on it today, but dont want to melt the rubber around it, any other suggestions?
thanks
Offline AudiA8Quattro
Re: seized bottom ball joint bolt?
« Reply #1 on: 19 June 2011, 10:15 »
I think you are talking about the pinch bolt?
Try opening up the clamp with a hammer and chisel, but go careful, it might be better with a strong screwdriver.
Other than that penetrating fluid, and a bit of heat if you can.
Offline Cory
« Reply #2 on: 19 June 2011, 10:20 »
sorry yeah, the one that connects the bottom of bearing housing to the wishbone.
will the housing come off the wishbone if the bolt is still in there but loose enough
on the joint if that makes sence?
bathed it in wd40, wil anything else work better?
« Reply #3 on: 19 June 2011, 10:34 »
Plus gas will probably be better.
You won't be able to disconnect it while the bolt is still in.
I would try opening up the clamp slightly, and see if you can move the bolt.
Put the nut back on the end of the bolt and hit it with a hammer.
Offline Cory
« Reply #4 on: 19 June 2011, 11:50 »
i spent a fair bit of time hitting it with a hammer. it seems to me like the head of the bolt is seized to the clamp, litter bugg*r!  :angry: ill have a go at opening up the clamp
