Author Topic: cold running problem,8v gti digifant.  (Read 1260 times)
Offline i_am_me
« on: 19 June 2011, 01:11 »
my digi has recently started having problems on the cold start.
when i start it i let the pump prime and then turn the engine over and it will fire but not start,but if i let it prime twice it starts straight away,but it cuts out again unless i keep a bit of throttle on.
it will also die if i put too much throttle on.
it clears after a Minuit or two and runs fine after that,and starts fine when its warm.
i assume its a fuel problem on the cold start but im not sure how to cure it.
also on the warm start it starts fine and idles normally for about 5 seconds then revs to 2000rpm and stays there for a Minuit or two.im not sure if its a related issue or not.
any suggestions?
<br />
If at first you don't succeed skydiving is not for you
Re: cold running problem,8v gti digifant.
« Reply #1 on: 19 June 2011, 14:53 »
Try a new temp sender as a 1st step.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #2 on: 20 June 2011, 18:46 »
+1
Also when was it last serviced? Plugs, HT Leads, dist Cap & Arm - might need replacing...
For More Info Click To See;
