Author Topic: Emissions fail  (Read 1876 times)
Offline Ludwig68
Emissions fail
« on: 18 June 2011, 17:33 »
Hi All
Got an issue with Mrs Ludwig's Mk3. Has failed MOT on emissions. So far garage has changed: plugs & leads, rotor arm & dizzy cap, Lamda switch. Compression test is all good (for a 130k engine) & there's no goo in the header tank. She runs fine but with a missfire between 2-3k revs. We've swapped the ECU from another car temporarily but the fault persists. fuel comsumption is terrible as it's running so rich. Any ideas?
Thanks
Offline Khare
  • The bear that khares
Re: Emissions fail
« Reply #1 on: 18 June 2011, 17:39 »
maybe the cat is past it's expiry date?
Offline Seanl
Re: Emissions fail
« Reply #2 on: 18 June 2011, 21:00 »
MAF.  :wink:
Re: Emissions fail
« Reply #3 on: 18 June 2011, 21:10 »
Coolant temp sensor., try a new one.
Offline madmanmart
Re: Emissions fail
« Reply #4 on: 18 June 2011, 22:05 »
MAF is a good start...
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline lankylari
Re: Emissions fail
« Reply #5 on: 18 June 2011, 22:21 »
had simailer problem change MAF sensor cat as had collapsed inside the put in lap top to find idle sensor fault, so changed throttle body no plblems now just flow throw mot on emissons just rear axle mounts and welding. all the best.
Offline AudiA8Quattro
Re: Emissions fail
« Reply #6 on: 18 June 2011, 22:27 »
I would run VAG com on it.
ECU coolant temp sender is a good place to start....
Offline Ludwig68
Re: Emissions fail
« Reply #7 on: 19 June 2011, 11:56 »
Thanks guys. Looks like MAF sensor change first. Er... where is it & does it matter if it's a 16v engine?
Ta
Offline madmanmart
Re: Emissions fail
« Reply #8 on: 19 June 2011, 13:30 »
Ta
Yes it does matter, the 16v does not have a MAF sensor.
Is the car a 8v or 16v?
Offline simc66
Re: Emissions fail
« Reply #9 on: 19 June 2011, 16:11 »
Misfire between 2-3k (and crap fuel consumption) on my 16v was a perished fuel pressure regulator hose.
1997 Mk3 Colour Concept, 2006 Polo GTI, 1987 Type 25
