Author Topic: turbo  (Read 2733 times)
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
turbo
« on: 16 June 2011, 19:21 »
rightt this might sound stupidd but im not sureee
could i just fit a turbo to my car?
i got a 1.6GL
and if i could what sort of boost would you see?
thank you
http://cgi.ebay.co.uk/vw-golf-mk3-turbo-/130521999428?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e63b7a844
Offline snifferdog
Re: turbo
« Reply #1 on: 16 June 2011, 19:46 »
Im gonna take a guess, as I dont know, but I reckon theres more to it than that. Probably the engine internals wont be able to cope and you would probably need a new engine management set up. :undecided:
Offline Khare
  • The bear that khares
Re: turbo
« Reply #2 on: 16 June 2011, 19:47 »
Too much work. Too much money. Not worth it  :smiley:
Offline VR6_Wherry
Re: turbo
« Reply #3 on: 16 June 2011, 19:49 »
I'm pretty sure that's fora diesel..
Offline trog_nfs
Re: turbo
« Reply #4 on: 16 June 2011, 19:54 »
:grin: :grin:
If your car is rot free it could be up for an engine conversion, but its a lot of work from a lower-engined car
Offline jamie_pyrite
Re: turbo
« Reply #5 on: 16 June 2011, 19:55 »
Must be.. they didn't do an OEM turbo engine on petrols. Feel free to buy it and see if you can make it fit :D It does need one or two other bits to go with it though ;)
Offline Dan_GTi8v
Re: turbo
« Reply #6 on: 16 June 2011, 20:05 »
thats from a 1.9 TDI engine code 1Z. Its a lot more complicated than just bolting it on :P
Offline jonnypolish
  • t2871r needed :)
Re: turbo
« Reply #7 on: 16 June 2011, 20:07 »
*cough* 20vt...
But you can in theory just bolt a tubby on if you can get the manifold etc...
Then you would need new management, which isn't cheap!
Could be banter though!
 MK2 VR y0!
Offline Dan_GTi8v
Re: turbo
« Reply #8 on: 16 June 2011, 20:14 »
check tshirt2k build thread to see whats involved in turboing a standard engine, he Turboed his 16v running megasquirt
Re: turbo
« Reply #9 on: 16 June 2011, 21:11 »
^^This
If you really want boost then fit a 1.8t
