Author Topic: help tdi engines  (Read 4746 times)
Offline Rhyso
Re: help tdi engines
« Reply #20 on: 17 June 2011, 21:58 »
to late :rolleyes:
Running that standard map innit  :tongue:
Offline AudiA8Quattro
« Reply #21 on: 17 June 2011, 21:59 »
Ouch  :evil:
So am i safe looking at pd 130's then?
Is there a cure? i take it the tappets have been modified?
Offline Rhyso
« Reply #22 on: 17 June 2011, 21:59 »
Ouch  :evil:
You're safer and yes they have been revised  :smiley:
« Reply #23 on: 17 June 2011, 22:01 »
So if i wanted either engine, should i budget for a new set of followers then?
Offline Rhyso
« Reply #24 on: 17 June 2011, 22:02 »
I would, just to be on the safe side.  Although on mine it was the turbo that went first  :grin: :grin:
It really is a lottery with regards to this issue but I know of more 150 engines suffering.  Another mate of mine had his fail a couple of months ago  :cry:
« Reply #25 on: 17 June 2011, 22:07 »
What are the symptoms? erratic idle? loss of power?
I take it, its an expensive fix!
Offline bodga
  • F reg GTI 16v
« Reply #26 on: 17 June 2011, 22:10 »
Friend of nine at work has a bora PD150 , his cam went and it cost him about £1800thats with a turbo because that failed too :huh:. only 80-90k on the clock thou, full FSH. he was well pissed
Offline Rhyso
« Reply #27 on: 17 June 2011, 22:11 »
As per Steve's thread
Symptoms where clicking sound after 2k rpm, white smoke on start up, excessive black smoke when driving and power surging. You could also hear the turbo stuttering
Offline Steve_PD
« Reply #28 on: 17 June 2011, 22:22 »
Mine cost £850, £600 in parts rest in labour
If you use a genuine camshaft it will cost over £800 in parts :lipsrsealed: some people say you should change the injector rocker arms which pushes the bill to over £1200
« Reply #29 on: 17 June 2011, 22:24 »
I thought diesels were reliable  :grin:
