Author Topic: Build Thread  (Read 91386 times)
Offline m.i.k.e
Re: Build Thread
« Reply #20 on: 21 June 2011, 19:30 »
Quick boot build, amateurish I know.
Interesting that you've put the fused end of the power cable in the boot if your battery is at the front....  :shocked:  Not going to give you any protection if the wire gives you a fault.
Really? I just assumed the fuse would blow where ever it is in the power cable.
Offline m.i.k.e
Re: Build Thread
« Reply #21 on: 26 June 2011, 23:27 »
Offline SoundillusioN
Re: Build Thread
« Reply #22 on: 27 June 2011, 05:59 »
^^^ awseome pic.
Don't know how best to explain this in short.
With the fuse where it is you are only protecting the final length of wire in your boot from the holder to the amp.  If you were to short the wire anywhere else before the fuse, the power would take the shortest route through the body, back to the battery easily causing a fire hazard.
Worse case scenario,  think of it this way, if the wires cover was to fail or was chaffing on something anywhere between the battery and your back seat area and eventually grounded, the stray power from the battery wouldn't even make it to the fuse, hence why they are always under the bonnet very close to the battery.
That make sense or do I sound like i'm talking cr@p?  :grin:
Offline Jack3559
Re: Build Thread
« Reply #23 on: 27 June 2011, 06:21 »
He's right ya know!  :wink:
Offline m.i.k.e
Re: Build Thread
« Reply #24 on: 01 July 2011, 00:57 »
Makes perfect sense! Best install a large blade fuse asap.
Offline m.i.k.e
Re: Build Thread
« Reply #25 on: 14 August 2011, 22:45 »
Vdub at the pub
Dubs at the park
Bristol volksfest
Gti international
Vag @ castle Combe
New dust caps!
Offline m.i.k.e
Re: Build Thread
« Reply #26 on: 14 August 2011, 23:02 »
The old mk3 8v
Offline lemski
  • 16v
Re: Build Thread
« Reply #27 on: 15 August 2011, 08:46 »
Looks good, I take its not wide tracked, as its on 9sall round
Re: Build Thread
« Reply #28 on: 15 August 2011, 10:05 »
Can you imagine if it was, those fronts are wide enough as it is!
Offline Jack3559
Re: Build Thread
« Reply #29 on: 15 August 2011, 10:47 »
Looks amazing on 9s.
