Author Topic: replacing rear abs sensor  (Read 2916 times)
VW BUSH
Re: replacing rear abs sensor
« Reply #20 on: 13 June 2011, 21:26 »
People are making it sound a lot worse than it actually is, yes they do get seized into position BUT it's still not a big job to replace them.
+1 easy job to do, I remove the scale from the hole with an old imperial size drill about .20mm bigger than the metric size.
This helps with the New sensors being a bit tighter in the hole, they dont like being banged in :wink:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #21 on: 14 June 2011, 00:28 »
Na they don't, ive had to file or grind down virtually every new sensor before fitment.
Offline tshirt2k
  • Been there...Done that...
« Reply #22 on: 14 June 2011, 08:34 »
Test the sensor before you remove it. Rear right fault can be a sign of ECU failure. Just had this. Changed sensor and fault is still there. And thats with a S/H replacement ECU fitted.
Mk3 ABF 16VT Megasquirt V3
Offline danmusic24
« Reply #23 on: 14 June 2011, 09:12 »
if it is the sensor would the fault go straight away or does it take a while for light to go out...heard somewhere it can take a few miles before light goes out.surly you can use vagcom to clear fault if it is sensor :smiley:
Offline AudiA8Quattro
« Reply #24 on: 14 June 2011, 11:02 »
If the problem has been solved, the light should go out as soon as you go over about 20mph, or it might be slower than that.
You won't need VAG com to reset it.
« Reply #25 on: 14 June 2011, 12:10 »
I think it's 15mph.
« Reply #26 on: 14 June 2011, 12:21 »
I think it's 15mph.
Yep thats probably it  :smiley:
