Author Topic: Fitting my aftermarket stereo help  (Read 6833 times)
Offline MK4_20VT
« on: 12 June 2011, 22:02 »
Quick question
Will this adaptor allow me to fit my aftermarket JVC stereo without needing to find an igniton live source
http://cgi.ebay.co.uk/VW-Golf-MK5-radio-stereo-wiring-harness-adapter-lead-/130508966982?pt=UK_Cars_Parts_Vehicles_Terminals_Cabling_ET&hash=item1e62f0cc46
As it says  some vehicles may require an extra power feed, this is readily available on the harness -  Red wire
Thanks
Offline _Adam_
Re: Fitting my aftermarket stereo help
« Reply #1 on: 13 June 2011, 09:15 »
thats not what i have for mine, but that's not to say it won't fit.
you need to join the red and yellow wires from the Cd player side, to the yellow wire from the car side. this should give you constant feed.
Offline MK4_20VT
« Reply #2 on: 13 June 2011, 17:22 »
Thanks _Adam_
So I take it you didn't need to run an ignition wire from the fuesbox to the stereo?
Jay
Offline _Adam_
« Reply #3 on: 13 June 2011, 21:46 »
nope, i used what was already in the loom. if you're desperate it's piss easy to pull it out and take a pic if you like
Offline dTEA
  • back in an MK5
« Reply #4 on: 16 June 2011, 01:10 »
Out of interest what's the radio reception like? Mine ain't great...and was wondering about the fuse of feed...
Edition 30 / T5 T32 Kombi
Offline AlanD
  • MK5 2.0T 16v
« Reply #5 on: 16 June 2011, 10:42 »
Ive got an aftermarket Alpine unit and the radio reception is pony even with a signal booster. Given up and just accepted that its going to be crap, mainly us MP3 CDs anyway.
FYI mine is an early model GTI without the roof antenna (looks so much cleaner and better) which might explain it?
Offline _Adam_
« Reply #6 on: 16 June 2011, 10:55 »
same and same
Offline dTEA
  • back in an MK5
« Reply #7 on: 16 June 2011, 22:05 »
^yup early 05 so no antenna either. Ah well. SD card or 32gb iPod 16gb and DVD should keep me happy  :grin:
Offline MK4_20VT
« Reply #8 on: 18 June 2011, 15:27 »
Ok the Stereo is installed, but I now have to turn it no/off myself plus it doesn't autodim when the lights go on
Looks like I am going to have to buy a Can-Bus adaptor
http://cgi.ebay.co.uk/VW-TOURAN-GOLF-V-PASSSAT-CAN-BUS-ADAPTOR-CAN-01-/290380689686?pt=LH_DefaultDomain_3&hash=item439c09b116
Oh well, least I get my MP3 & DAB back
Jay
Offline dTEA
  • back in an MK5
« Reply #9 on: 18 June 2011, 17:57 »
Canbus is the only way to auto dim unless using OEM units. You may also have permanent live feed instead of ignition live?
